Sort Movies by Aspect Ratio (Trying to Identify Full Screen Movies)
Is there a way to sort the movies in your Plex library (or otherwise derive a list) by Aspect Ratio? I need an easy way to identify any of my movies that are full screen versions. This doesn’t seem to be an option in the “List View”. Maybe there’s a utility or configuration file somewhere where I can somewhat easily get that information (other than clicking each title, clicking “More” and clicking “Get Info”)?
Now that I have all of my movies online in Plex I want to slowly start to “upgrade” all of my older full screen versions to widescreen versions where they’re available. Any ideas would be appreciated! Thanks!
Well for anyone trying to do the same thing, I did figure out a way to get close to this by querying the Plex database directly. Here’s the process I used for anyone else looking to do the same thing:
  1. Save a backup copy of your Plex database. Open your Plex interface in a web browser, on the left navigate to SETTINGS | HELP and click the “Download Database” button. Call the file whatever you want but be sure to change the extension to “.DB”
  2. Open up your favorite SQLite application. I used DB Browser for SQLite available at: sqlitebrowser.org/.
  3. Execute the following SQL query (the “Execute SQL” tab in DB Browser for SQLite):
    SELECT metadata_items.title, media_items.display_aspect_ratio
    FROM media_items
    LEFT OUTER JOIN metadata_items
    ON media_items.metadata_item_id=metadata_items.id
    WHERE metadata_items.metadata_type=‘1’
    AND media_items.display_aspect_ratio LIKE ‘1.3%’
    ORDER BY metadata_items.title
In general the Plex agent seems to identify full screen movies with an aspect ratio of 1.33. It’s not always 100% correct from what I’ve seen but it at least gets you close.
Please feel free to let me know if there’s an easier way or something a little more authoritative. Thanks!
To anyone else finding this: You need to replace the ’ in the code block, with '.
Correct version:
FROM media_items
