assetUrl not working anymore?
ZDF plugin stopped working after update
Hi!
The author of the "popular german [ZDFmediathek](http://forums.plexapp.com/index.php?showtopic=3940&st=0&p=25680&#entry25680) plugin is currently busy. So I am asking for help in the english board section. The plugin stopped working since the last plex update.
Here are two logs:
Library/Logs/PMS Plugin Logs/com.plexapp.plugins.zdfmediathek.log
16:45:14.871691: com.plexapp.plugins.zdfmediathek:   parseVideoItem: /ZDFmediathek/content/heute_100SEC/9280/257404<br />
16:45:14.871850: com.plexapp.plugins.zdfmediathek:   url: http://www.zdf.de/ZDFmediathek/content/heute_100SEC/9280/257404?bw=dsl2000&pp=vlc&view=navJson<br />
16:45:15.026624: com.plexapp.plugins.zdfmediathek:   assetUrl: http://wstreaming.zdf.de/zdf/veryhigh/090302_1610_hko.asx
Plex.log:
19:39:56 T:2691933984 M:443097088  NOTICE: DVDPlayer: Opening: mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/04/090415_1917_hko_vh.wmv<br />
19:39:56 T:2691933984 M:443097088 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED<br />
19:39:56 T:2975334400 M:443088896  NOTICE: Creating InputStream<br />
19:39:56 T:2975334400 M:427302912  NOTICE: Creating Demuxer<br />
19:39:56 T:2975334400 M:427270144   ERROR: Open - Error, could not open file mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/04/090415_1917_hko_vh.wmv<br />
19:39:56 T:2975334400 M:427286528   ERROR: OpenDemuxStream - Error creating demuxer<br />
19:39:56 T:2975334400 M:427286528  NOTICE: CDVDPlayer::OnExit()<br />
19:39:56 T:2975334400 M:427286528  NOTICE: CDVDPlayer::OnExit() deleting input stream<br />
19:39:57 T:2691933984 M:443088896  NOTICE: CDVDPlayer::CloseFile()<br />
19:39:57 T:2691933984 M:443105280 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED<br />
19:39:57 T:2691933984 M:443105280  NOTICE: DVDPlayer: waiting for threads to exit<br />
19:39:57 T:2691933984 M:443142144  NOTICE: DVDPlayer: finished waiting<br />
19:39:57 T:2691933984 M:443142144   ERROR: Playlist Player: skipping unplayable item: 0, path [mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/04/090415_1917_hko_vh.wmv]
Problem is that Plex doesn’t want to play the mms stream anymore, here
I just checked Plex 0.7.11 on my MacBook and there it still works. Streams also play perfectly in VLC or mplayer.
If it opens the stream in 0.7.13 and not in 0.7.14 then there’s a good chance it’s related to the ffmpeg upgrade that’s in 0.7.14 - in which case I’d say the best thing would be to create a ticket at http://plexapp.lighthouseapp.com/ with the logs you provided up top.
If you do attach a log, please enable debug logging in the advanced settings dialog first - it’ll provide much more detailed output :slight_smile: Thanks!
Well it’s not a ffmpeg related problem I think.
I can run the stream without a problem form the command line.
/Applications/Plex.app/Contents/MacOS/Plex http://wstreaming.zdf.de/zdf/veryhigh/090414_h19.asx<br />
The PLEX_HOME environment variable is not set.<br />
XBOX360: Registering for notifications.<br />
Adding 39 Apple Remote cookies.<br />
Saving old default of Built-in Output<br />
Loading file: /Applications/Plex.app/Contents/Resources/Plex/language/German/langinfo.xml<br />
Computing cache size for [mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/04/090414_h19_vh.wmv].<br />
Setting video cache size to 4096KB<br />
Setting audio cache size to 2048KB<br />
Input #0, asf, from 'mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/04/090414_h19_vh.wmv':<br />
  Duration: 00:21:46.87, start: 2.000000, bitrate: N/A<br />
	Stream #0.0: Audio: wmav2, 44100 Hz, stereo, s16, 192 kb/s<br />
	Stream #0.1: Video: wmv3, yuv420p, 688x384, 1400 kb/s, 25 tbr, 1k tbn, 1k tbc
So I guess it's more a Media Server Plugin problem.
Could be wrong though :)
Here is the DEBUG log:
Just a GUESS … can we force the playback with MPLAYER instead of DVDplayer? … would that make a difference?
[codebox]11:25:41 T:2693658400 M:2345951232 DEBUG: OnKey: 61453 pressed, action is 7
11:25:41 T:2693658400 M:2345893888 INFO: easy_aquire - Created session to http://ondemand.msmedia.zdf.newmedia.nacamar.net
11:25:41 T:2693658400 M:2345910272 DEBUG: Curl:: Debug About to connect() to ondemand.msmedia.zdf.newmedia.nacamar.net port 80 (#0)
11:25:41 T:2693658400 M:2345910272 DEBUG: Curl:: Debug Trying 62.27.26.34…
11:25:41 T:2693658400 M:2345910272 DEBUG: Curl:: Debug connected
11:25:41 T:2693658400 M:2345910272 DEBUG: Curl:: Debug Connected to ondemand.msmedia.zdf.newmedia.nacamar.net (62.27.26.34) port 80 (#0)
11:25:41 T:2693658400 M:2345910272 DEBUG: Curl:: Debug HEAD /zdf/data/msmedia/zdf/09/03/090330_limes2_tex_vh.wmv HTTP/1.1
User-Agent: Plex Firefox/2.0.0.11
Host: ondemand.msmedia.zdf.newmedia.nacamar.net
Accept: /
Connection: keep-alive
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug The requested URL returned error: 501
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Closing connection #0
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug HTTP response code said error
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug About to connect() to ondemand.msmedia.zdf.newmedia.nacamar.net port 80 (#0)
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Trying 62.27.26.34…
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug connected
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Connected to ondemand.msmedia.zdf.newmedia.nacamar.net (62.27.26.34) port 80 (#0)
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug GET /zdf/data/msmedia/zdf/09/03/090330_limes2_tex_vh.wmv HTTP/1.1
Range: bytes=0-0
Accept: /
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug HTTP/1.1 200 OK
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Content-Type: video/x-ms-wvx
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Cache-Control: max-age=0, no-cache
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Server: Cougar/9.01.01.5000
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Content-Length: 226
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Date: Fri, 01 May 2009 18:25:29 GMT
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Pragma: no-cache, xResetStrm=1
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Supported: com.microsoft.wm.srvppair, com.microsoft.wm.sswitch, com.microsoft.wm.predstrm, com.microsoft.wm.fastcache, com.microsoft.wm.startupprofile
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Connection: close
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Failed writing body (0 != 226)
11:25:41 T:2693658400 M:2345902080 DEBUG: Curl:: Debug Failed writing received data to disk/application
11:25:41 T:2693658400 M:2345902080 DEBUG: FileCurl::Close(0xbfffde0c) http://ondemand.msmedia.zdf.newmedia.nacam…mes2_tex_vh.wmv
11:25:41 T:2693658400 M:2345889792 DEBUG: Curl:: Debug About to connect() to ondemand.msmedia.zdf.newmedia.nacamar.net port 80 (#0)
11:25:41 T:2693658400 M:2345889792 DEBUG: Curl:: Debug Trying 62.27.26.34…
11:25:41 T:2693658400 M:2345869312 DEBUG: Curl:: Debug connected
11:25:41 T:2693658400 M:2345869312 DEBUG: Curl:: Debug Connected to ondemand.msmedia.zdf.newmedia.nacamar.net (62.27.26.34) port 80 (#0)
11:25:41 T:2693658400 M:2345869312 DEBUG: Curl:: Debug HEAD /zdf/data/msmedia/zdf/09/03/090330_limes2_tex_vh.wmv HTTP/1.1
User-Agent: NSPlayer/11.00.6001.7000
Accept: /
11:25:42 T:2693658400 M:2345869312 DEBUG: Curl:: Debug The requested URL returned error: 501
11:25:42 T:2693658400 M:2345869312 DEBUG: Curl:: Debug Closing connection #0
11:25:42 T:2693658400 M:2345869312 DEBUG: Curl:: Debug HTTP response code said error
11:25:42 T:2693658400 M:2345869312 DEBUG: Curl:: Debug About to connect() to ondemand.msmedia.zdf.newmedia.nacamar.net port 80 (#0)
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Trying 62.27.26.34…
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug connected
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Connected to ondemand.msmedia.zdf.newmedia.nacamar.net (62.27.26.34) port 80 (#0)
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug GET /zdf/data/msmedia/zdf/09/03/090330_limes2_tex_vh.wmv HTTP/1.1
Range: bytes=0-0
Accept: /
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug HTTP 1.0, assume close after body
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug HTTP/1.0 200 OK
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Content-Type: application/vnd.ms.wms-hdr.asfv1
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Server: Cougar/9.01.01.5000
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Content-Length: 3044
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Date: Fri, 01 May 2009 18:25:30 GMT
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Pragma: no-cache, client-id=3245947118, xResetStrm=1, features=“seekable,stridable”, timeout=60000
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Cache-Control: no-cache, x-wms-content-size=515243970, max-age=86399, proxy-public, proxy-revalidate
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Last-Modified: Wed, 01 Apr 2009 05:09:56 GMT
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Etag: “515243970”
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Supported: com.microsoft.wm.srvppair, com.microsoft.wm.sswitch, com.microsoft.wm.predstrm, com.microsoft.wm.fastcache, com.microsoft.wm.startupprofile
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Failed writing body (0 != 874)
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Closing connection #0
11:25:42 T:2693658400 M:2345865216 DEBUG: Curl:: Debug Failed writing received data to disk/application
11:25:42 T:2693658400 M:2345865216 DEBUG: FileCurl::Close(0xbfffde0c) http://ondemand.msmedia.zdf.newmedia.nacam…mes2_tex_vh.wmv
11:25:42 T:2693658400 M:2345865216 DEBUG: new file set audiostream:0
11:25:42 T:2693658400 M:2345828352 DEBUG: CPlayerCoreFactor::GetPlayers(mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/03/090330_limes2_tex_vh.wmv)
11:25:42 T:2693658400 M:2345844736 DEBUG: file:mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/03/090330_limes2_tex_vh.wmv IsDVDImage:0 IsDVDIfoFile:0
11:25:42 T:2693658400 M:2345844736 INFO: Loading skin file: DialogProgress.xml
11:25:42 T:2693658400 M:2345844736 DEBUG: Load DialogProgress.xml: 1.46ms (0.41 ms xml load)
11:25:42 T:2693658400 M:2345844736 DEBUG: DialogProgress::StartModal called
11:25:42 T:2693658400 M:2345844736 DEBUG: ------------------- GUI_MSG_WINDOW_INIT
11:25:42 T:2693658400 M:2345844736 DEBUG: Progress dialog
11:25:42 T:2693658400 M:2345844736 DEBUG: Load DialogBigButtonFO.png: 0.2ms (bundled)
11:25:42 T:2693658400 M:2345844736 DEBUG: Load DialogBigButtonNF.png: 0.2ms (bundled)
11:25:42 T:2693658400 M:2345844736 DEBUG: Alloc resources: 0.90ms (0.04 ms skin load, 0.10 ms preload)
11:25:42 T:2968440832 M:2345836544 DEBUG: Running thread 2968440832
11:25:42 T:2693658400 M:2345836544 NOTICE: DVDPlayer: Opening: mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/03/090330_limes2_tex_vh.wmv
11:25:42 T:2968440832 M:2345836544 DEBUG: thread start, auto delete: 1
11:25:42 T:2693658400 M:2345836544 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
11:25:42 T:2968973312 M:2345824256 DEBUG: Running thread 2968973312
11:25:42 T:2968973312 M:2345824256 DEBUG: thread start, auto delete: 0
11:25:42 T:2968973312 M:2345824256 NOTICE: Creating InputStream
11:25:42 T:2968973312 M:2330079232 DEBUG: CFileCache::Open - opening <zdf/data/msmedia/zdf/09/03/090330_limes2_tex_vh.wmv> using cache
11:25:42 T:2968973312 M:2330066944 DEBUG: MMS: socket connected
11:25:43 T:2968973312 M:2328563712 INFO: MMS: asf header packet detected, len=2486
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS: header read successful
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS: guid found: 6553200cc000e48e11cfa9478cabdca1
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS guid: file object, packet length = 8948 (8948)
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS: guid found: 6553200cc000e38e11cfa92e5fbf03b5
11:25:43 T:2968973312 M:2328555520 INFO: MMS guid: unknown object
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS: guid found: 50a85ec9a000f09711d2e307d2d0a440
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS: guid found: 6553200cc000e68e11cfa9b7b7dc0791
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS guid: stream object, stream_id=1
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS guid: stream object, stream_id=2
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS: guid found: b2a2c9976000828d11d1468d7bf875ce
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS: guid found: f64803c9a000a4a311d0311d86d15240
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS: guid found: 6cce6200aa00d9a611cf668e75b22633
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS: guid found: 6cce6200aa00d9a611cf668e75b22636
11:25:43 T:2968973312 M:2328555520 DEBUG: MMS guid: data object
11:25:44 T:2968973312 M:2328543232 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles
11:25:44 T:2969505792 M:2328543232 DEBUG: Running thread 2969505792
11:25:44 T:2968973312 M:2328543232 DEBUG: CacheSubtitles: START
11:25:44 T:2969505792 M:2328543232 DEBUG: thread start, auto delete: 0
11:25:44 T:2968973312 M:2328526848 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles done
11:25:44 T:2968973312 M:2328526848 NOTICE: Creating Demuxer
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[0] = 01 (1)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[1] = 00 (0)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[2] = 00 (0)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[3] = 4a (74)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[4] = ce (206)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[5] = fa (250)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[6] = 0b (11)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[7] = b0 (176)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[0] = 00 (0)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[3] = 00 (0)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[4] = 04 (4)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[5] = 00 (0)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[6] = fa (250)
11:25:44 T:2969505792 M:2328465408 DEBUG: MMS: pre_header[7] = 22 (34)
11:25:44 T:2969505792 M:2328436736 DEBUG: MMS: pre_header[0] = 01 (1)
11:25:44 T:2969505792 M:2328436736 DEBUG: MMS: pre_header[1] = 00 (0)
11:25:44 T:2969505792 M:2328436736 DEBUG: MMS: pre_header[2] = 00 (0)
11:25:44 T:2969505792 M:2328436736 DEBUG: MMS: pre_header[3] = 00 (0)
11:25:44 T:2969505792 M:2328436736 DEBUG: MMS: pre_header[4] = 04 (4)
11:25:44 T:2969505792 M:2328436736 DEBUG: MMS: pre_header[5] = 01 (1)
11:25:44 T:2969505792 M:2328436736 DEBUG: MMS: pre_header[6] = f9 (249)
11:25:44 T:2969505792 M:2328436736 DEBUG: MMS: pre_header[7] = 22 (34)
11:25:44 T:2968973312 M:2328428544 INFO: Open - probing detected format [asf]
11:25:44 T:2968973312 M:2328412160 ERROR: Open - Error, could not open file mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/03/090330_limes2_tex_vh.wmv
11:25:44 T:2968973312 M:2328428544 ERROR: OpenDemuxStream - Error creating demuxer
11:25:44 T:2968973312 M:2328428544 NOTICE: CDVDPlayer::OnExit()
11:25:44 T:2968973312 M:2328428544 NOTICE: CDVDPlayer::OnExit() deleting input stream
11:25:44 T:2969505792 M:2328440832 DEBUG: staticThread, deleting thread graphic context
11:25:44 T:2969505792 M:2328440832 DEBUG: Thread 2969505792 terminating
11:25:44 T:2968973312 M:2344222720 DEBUG: ------------------- GUI_MSG_WINDOW_DEINIT
11:25:44 T:2968973312 M:2344222720 DEBUG: Progress dialog
11:25:44 T:2968973312 M:2344222720 DEBUG: GL: Sharing screen surface for thread 2968973312
11:25:44 T:2968973312 M:2344222720 DEBUG: Playback was stopped
11:25:44 T:2968973312 M:2344222720 DEBUG: staticThread, deleting thread graphic context
11:25:44 T:2968973312 M:2344222720 DEBUG: Thread 2968973312 terminating
11:25:44 T:2693658400 M:2344194048 NOTICE: CDVDPlayer::CloseFile()
11:25:44 T:2693658400 M:2344210432 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
11:25:44 T:2693658400 M:2344210432 NOTICE: DVDPlayer: waiting for threads to exit
11:25:44 T:2693658400 M:2344243200 NOTICE: DVDPlayer: finished waiting
11:25:44 T:2693658400 M:2344243200 ERROR: Playlist Player: skipping unplayable item: 0, path [mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/03/090330_limes2_tex_vh.wmv]
11:25:44 T:2693658400 M:2344243200 DEBUG: Playlist Player: no more playable items… aborting playback
11:25:44 T:2967375872 M:2344255488 DEBUG: Running thread 2967375872
11:25:44 T:2967375872 M:2344255488 DEBUG: thread start, auto delete: 0
11:25:44 T:2967908352 M:2344247296 DEBUG: Running thread 2967908352
11:25:44 T:2967908352 M:2344247296 DEBUG: thread start, auto delete: 0
11:25:44 T:2967908352 M:2344333312 DEBUG: staticThread, deleting thread graphic context
11:25:44 T:2967908352 M:2344333312 DEBUG: Thread 2967908352 terminating
11:25:44 T:2967375872 M:2344333312 DEBUG: staticThread, deleting thread graphic context
11:25:44 T:2967375872 M:2344333312 DEBUG: Thread 2967375872 terminating
11:25:44 T:2693658400 M:2344595456 DEBUG: SDLKeyboard found something unknown (unicode <> printable ASCII): scancode: 0, sym: 310, unicode: 0, modifier: 0
11:25:44 T:2968440832 M:2344599552 DEBUG: staticThread, deleting thread object
11:25:44 T:2968440832 M:2344599552 DEBUG: staticThread, deleting thread graphic context
11:25:44 T:2968440832 M:2344599552 DEBUG: Thread 2968440832 terminating
11:26:08 T:2693658400 M:2346225664 INFO: CheckIdle - Closing session to http ://localhost (easy=0x1aa65000, multi=0x1b54cd30)
11:26:10 T:2693658400 M:2346225664 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\ImageLib-osx.so)
11:26:10 T:2693658400 M:2346225664 DEBUG: Unloading: ImageLib-osx.so
11:26:12 T:2693658400 M:2346262528 INFO: CheckIdle - Closing session to http ://ondemand.msmedia.zdf.newmedia.nacamar.net (easy=0x1b275000, multi=0x0)
11:26:43 T:2693658400 M:2346881024 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\libcurl-osx.so)
11:26:43 T:2693658400 M:2346881024 DEBUG: Unloading: libcurl-osx.so
[/codebox]
How are you returning those links to Plex from the Media Server? It looks like it’s trying to open an HTTP connection. The mms:// stream plays fine if I put it in an strm file.
Basically, you can’t play these sorts of streams from HTTP because it doesn’t redirect to MMS. If you return it as MMS via a VideoItem it should play fine, I think, but I’d have to see the plug-in and what it’s doing.
You can also hit the media server from Firefox (e.g. http://localhost:32400/video/)) and paste in the XML it’s returning with the videos in them.
I change the protocol header because this is what I have to do to make the stream work within MPC on my windows machine.
I put the stream:
"mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/03/090327_kochen_lko_vh.wmv"
into a file called "test.strm" ==> same error "Open - Error, could not open mms:// ..."
My PLUGIN is here:
[http://wiki.plexapp.com/index.php/COMPIZmediacenter](http://wiki.plexapp.com/index.php/COMPIZmediacenter)
Just click on the first item in each of the menus ... until you see the streams ...
The "def cleanProtocol(url):" is where I SWITCH the protocol header from rtsp to http ... or to try out what you suggested above ... to MMS.
mmmhhh I am a little lost here ... when I put the URL into Firefox .. all I get is the MAIN mediacontainer of the VIDEO menu:
 −<br />
<MediaContainer size="25"><br />
<Directory key="4oD" name="4oD Catch-Up" thumb="/video/4oD/:/resources/icon-default.png" art="/video/4oD/:/resources/art-default.png"/><br />
<Directory key="AcademicEarth" name="Academic Earth" thumb="/video/AcademicEarth/:/resources/icon-default.png" art="/video/AcademicEarth/:/resources/art-default.png"/><br />
<Directory key="CNN" name="CNN" thumb="/video/CNN/:/resources/icon-default.png" art="/video/CNN/:/resources/art-default.png"/><br />
<Directory key="COMPIZmediacenter" name="COMPIZmediacenter" thumb="/video/COMPIZmediacenter/:/resources/thumb-art.jpg" art="/video/COMPIZmediacenter/:/resources/background-art.png"/>
The videos being returned, which can be seen by hitting:
http://localhost:32400/video/COMPIZmediacenter/:/function/LevelTwoMenu/KGRwMApTJ3VybCcKcDEKUydwY2gucGhwP3M9aGV1dGUnCnAyCnNTJ2FsdCcKcDMKUydoZXV0ZScKcDQK<br />
c1MncGFwYScKcDUKUydaREYgTWVkaWF0aGVrJwpwNgpzUyd0aHVtYicKcDcKUydodHRwOi8vd3d3LnpkZ<br />
i5kZS9aREYvc19pbWcvMzgvMCw2NzUyLDU5MjkyNTQtcmVuZGVyLU0zLDAwLmpwZycKcDgKc1Mnc2VuZG<br />
VyJwpwOQooaVBNUy5PYmplY3RzCkl0ZW1JbmZvUmVjb3JkCnAxMAooZHAxMQpTJ2l0ZW1UaXRsZScKcDE<br />
yCmc0CnNTJ3RpdGxlMScKcDEzClMnQ09NUElabWVkaWFjZW50ZXInCnAxNApzUyd0aXRsZTInCnAxNQpn<br />
NgpzUydhcnQnCnAxNgpTJy92aWRlby9DT01QSVptZWRpYWNlbnRlci86L3Jlc291cmNlcy9iYWNrZ3Jvd<br />
W5kLWFydC5wbmcnCnAxNwpzYnMu
Are of the rtsp protocol. If you change the rtsp:// to http://, they play fine for me, around line 305:
dir.Append(VideoItem(URL.replace('rtsp://','http://'),
Got this … this is great the ability to see any mediacontainer … just cut and paste the location from the LOG …
Here is what I got after I changed the code as you suggested:
(took out my cleanHTML routine and changed the URL on the spot at line #305)
[codebox]06:27:30 T:2970038272 M:1877344256 DEBUG: staticThread, deleting thread graphic context
06:27:30 T:2970038272 M:1877344256 DEBUG: Thread 2970038272 terminating
06:27:30 T:2693658400 M:1877344256 DEBUG: ------------------- GUI_MSG_WINDOW_DEINIT
06:27:30 T:2693658400 M:1877344256 DEBUG: Progress dialog
06:27:30 T:2693658400 M:1877979136 DEBUG: host name = ondemand.msmedia.zdf.newmedia.nacamar.net
06:27:30 T:2693658400 M:1877979136 DEBUG: FileCurl::Close(0x1b3e9988)
06:27:30 T:2693658400 M:1878392832 DEBUG: Saving fileitems [plex://localhost/video/COMPIZmediacenter/:/function/LevelTwoMenu/KGRwMApTJ3VybCcKcDEKUydwY2gucGhwP3M9dGVycmEreCcKcDIKc1MnYWx0JwpwMwpTJ3RlcnJhIHgn
CnA0CnNTJ3BhcGEnCnA1ClMnWkRGIE1lZGlhdGhlaycKcDYKc1MndGh1bWInCnA3ClMnaHR0cDovL3d3
d
y56ZGYuZGUvWkRGZGUvc19pbWcvOTYvMCw2OTkyLDcwNTM2NjQtcmVuZGVyLU0zLDAwLmpwZycKcDgKc
1
Mnc2VuZGVyJwpwOQooaVBNUy5PYmplY3RzCkl0ZW1JbmZvUmVjb3JkCnAxMAooZHAxMQpTJ2l0ZW1UaX
R
sZScKcDEyCmc0CnNTJ3RpdGxlMScKcDEzClMnQ09NUElabWVkaWFjZW50ZXInCnAxNApzUyd0aXRsZTI
n
CnAxNQpnNgpzUydhcnQnCnAxNgpTJy92aWRlby9DT01QSVptZWRpYWNlbnRlci86L3Jlc291cmNlcy9i
Y
WNrZ3JvdW5kLWFydC5wbmcnCnAxNwpzYnMu/]
06:27:30 T:2693658400 M:1878392832 DEBUG: – items: 11, sort method: 0, ascending: false
06:27:30 T:2958389248 M:1880244224 DEBUG: Running thread 2958389248
06:27:30 T:2967375872 M:1880244224 DEBUG: Running thread 2967375872
06:27:30 T:2958389248 M:1880244224 DEBUG: thread start, auto delete: 0
06:27:30 T:2967375872 M:1880240128 DEBUG: thread start, auto delete: 0
06:27:30 T:2958389248 M:1880240128 DEBUG: staticThread, deleting thread graphic context
06:27:30 T:2967375872 M:1880240128 DEBUG: staticThread, deleting thread graphic context
06:27:30 T:2958389248 M:1880240128 DEBUG: Thread 2958389248 terminating
06:27:30 T:2967375872 M:1880240128 DEBUG: Thread 2967375872 terminating
06:27:30 T:2693658400 M:1880141824 DEBUG: PICTURE: loaded image and created texture. height: 54, width: 116
06:27:30 T:2693658400 M:1880170496 DEBUG: Load /Users/plex/Library/Application Support/Plex/userdata/Thumbnails/Video/d/d93015e3.tbn: 17.7ms
06:27:30 T:2693658400 M:1880014848 DEBUG: Load rating0.png: 0.3ms (bundled)
06:27:30 T:2693658400 M:1879896064 DEBUG: Load MediaItemBG.png: 0.7ms (bundled)
06:27:30 T:2693658400 M:1879396352 DEBUG: Load MenuItemFO.png: 0.9ms (bundled)
06:27:30 T:2693658400 M:1879257088 DEBUG: Load MediaItemDetailBG.png: 0.2ms (bundled)
06:27:31 T:2693658400 M:1878724608 INFO: easy_aquire - Created session to http://ondemand.msmedia.zdf.newmedia.nacamar.net
06:27:31 T:2693658400 M:1878740992 DEBUG: Curl:: Debug About to connect() to ondemand.msmedia.zdf.newmedia.nacamar.net port 80 (#0)
06:27:31 T:2693658400 M:1878740992 DEBUG: Curl:: Debug Trying 62.27.26.34…
06:27:31 T:2693658400 M:1878634496 DEBUG: Curl:: Debug connected
06:27:31 T:2693658400 M:1878634496 DEBUG: Curl:: Debug Connected to ondemand.msmedia.zdf.newmedia.nacamar.net (62.27.26.34) port 80 (#0)
06:27:31 T:2693658400 M:1878634496 DEBUG: Curl:: Debug HEAD /zdf/data/msmedia/zdf/09/04/090426_videochat_kieling_tex_vh.wmv HTTP/1.1
Accept: /
06:27:31 T:2693658400 M:1878650880 DEBUG: Curl:: Debug The requested URL returned error: 501
06:27:31 T:2693658400 M:1878650880 DEBUG: Curl:: Debug Closing connection #0
06:27:31 T:2693658400 M:1878646784 DEBUG: Curl:: Debug HTTP response code said error
06:27:31 T:2693658400 M:1878646784 DEBUG: Curl:: Debug About to connect() to ondemand.msmedia.zdf.newmedia.nacamar.net port 80 (#0)
06:27:31 T:2693658400 M:1878646784 DEBUG: Curl:: Debug Trying 62.27.26.34…
06:27:31 T:2693658400 M:1878519808 DEBUG: Curl:: Debug connected
06:27:31 T:2693658400 M:1878519808 DEBUG: Curl:: Debug Connected to ondemand.msmedia.zdf.newmedia.nacamar.net (62.27.26.34) port 80 (#0)
06:27:31 T:2693658400 M:1878519808 DEBUG: Curl:: Debug GET /zdf/data/msmedia/zdf/09/04/090426_videochat_kieling_tex_vh.wmv HTTP/1.1
Range: bytes=0-0
Accept: /
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug HTTP/1.1 200 OK
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Content-Type: video/x-ms-wvx
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Cache-Control: max-age=0, no-cache
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Server: Cougar/9.01.01.5000
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Content-Length: 248
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Date: Sat, 02 May 2009 13:27:21 GMT
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Pragma: no-cache, xResetStrm=1
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Supported: com.microsoft.wm.srvppair, com.microsoft.wm.sswitch, com.microsoft.wm.predstrm, com.microsoft.wm.fastcache, com.microsoft.wm.startupprofile
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Connection: close
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Failed writing body (0 != 248)
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Closing connection #0
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Failed writing received data to disk/application
06:27:32 T:2693658400 M:1878495232 DEBUG: FileCurl::Close(0xbfffddbc) http://ondemand.msmedia.zdf.newmedia.nacam…ling_tex_vh.wmv
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug About to connect() to ondemand.msmedia.zdf.newmedia.nacamar.net port 80 (#0)
06:27:32 T:2693658400 M:1878495232 DEBUG: Curl:: Debug Trying 62.27.26.34…
06:27:32 T:2693658400 M:1878577152 DEBUG: Curl:: Debug connected
06:27:32 T:2693658400 M:1878577152 DEBUG: Curl:: Debug Connected to ondemand.msmedia.zdf.newmedia.nacamar.net (62.27.26.34) port 80 (#0)
06:27:32 T:2693658400 M:1878577152 DEBUG: Curl:: Debug HEAD /zdf/data/msmedia/zdf/09/04/090426_videochat_kieling_tex_vh.wmv HTTP/1.1
Accept: /
06:27:32 T:2693658400 M:1878650880 DEBUG: Curl:: Debug The requested URL returned error: 501
06:27:32 T:2693658400 M:1878650880 DEBUG: Curl:: Debug Closing connection #0
06:27:32 T:2693658400 M:1878650880 DEBUG: Curl:: Debug HTTP response code said error
06:27:32 T:2693658400 M:1878650880 DEBUG: Curl:: Debug About to connect() to ondemand.msmedia.zdf.newmedia.nacamar.net port 80 (#0)
06:27:32 T:2693658400 M:1878650880 DEBUG: Curl:: Debug Trying 62.27.26.34…
06:27:32 T:2693658400 M:1878650880 DEBUG: Curl:: Debug connected
06:27:32 T:2693658400 M:1878650880 DEBUG: Curl:: Debug Connected to ondemand.msmedia.zdf.newmedia.nacamar.net (62.27.26.34) port 80 (#0)
06:27:32 T:2693658400 M:1878650880 DEBUG: Curl:: Debug GET /zdf/data/msmedia/zdf/09/04/090426_videochat_kieling_tex_vh.wmv HTTP/1.1
Range: bytes=0-0
Accept: /
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug HTTP 1.0, assume close after body
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug HTTP/1.0 200 OK
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Content-Type: application/vnd.ms.wms-hdr.asfv1
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Server: Cougar/9.01.01.5000
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Content-Length: 3055
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Date: Sat, 02 May 2009 13:27:22 GMT
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Pragma: no-cache, client-id=858120829, xResetStrm=1, features=“seekable,stridable”, timeout=60000
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Cache-Control: no-cache, x-wms-content-size=752202978, max-age=86399, proxy-public, proxy-revalidate
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Last-Modified: Sun, 26 Apr 2009 20:03:44 GMT
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Etag: “752202978”
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Supported: com.microsoft.wm.srvppair, com.microsoft.wm.sswitch, com.microsoft.wm.predstrm, com.microsoft.wm.fastcache, com.microsoft.wm.startupprofile
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Failed writing body (0 != 875)
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Closing connection #0
06:27:32 T:2693658400 M:1878609920 DEBUG: Curl:: Debug Failed writing received data to disk/application
06:27:32 T:2693658400 M:1878609920 DEBUG: FileCurl::Close(0xbfffddbc) http://ondemand.msmedia.zdf.newmedia.nacam…ling_tex_vh.wmv
06:27:32 T:2693658400 M:1878609920 DEBUG: new file set audiostream:0
06:27:32 T:2693658400 M:1878573056 DEBUG: CPlayerCoreFactor::GetPlayers(mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/04/090426_videochat_kieling_tex_vh.wmv)
06:27:32 T:2693658400 M:1878589440 DEBUG: file:mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/04/090426_videochat_kieling_tex_vh.wmv IsDVDImage:0 IsDVDIfoFile:0
06:27:32 T:2693658400 M:1878589440 INFO: Loading skin file: DialogProgress.xml
06:27:32 T:2693658400 M:1878585344 DEBUG: Load DialogProgress.xml: 1.76ms (0.39 ms xml load)
06:27:32 T:2693658400 M:1878585344 DEBUG: DialogProgress::StartModal called
06:27:32 T:2693658400 M:1878585344 DEBUG: ------------------- GUI_MSG_WINDOW_INIT
06:27:32 T:2693658400 M:1878585344 DEBUG: Progress dialog
06:27:32 T:2693658400 M:1878552576 DEBUG: Load DialogBigButtonFO.png: 0.2ms (bundled)
06:27:32 T:2693658400 M:1878519808 DEBUG: Load DialogBigButtonNF.png: 0.2ms (bundled)
06:27:32 T:2693658400 M:1878519808 DEBUG: Alloc resources: 1.00ms (0.04 ms skin load, 0.11 ms preload)
06:27:32 T:2967908352 M:1878511616 DEBUG: Running thread 2967908352
06:27:32 T:2693658400 M:1878511616 NOTICE: DVDPlayer: Opening: mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/04/090426_videochat_kieling_tex_vh.wmv
06:27:32 T:2967908352 M:1878511616 DEBUG: thread start, auto delete: 1
06:27:32 T:2693658400 M:1878511616 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
06:27:32 T:2968440832 M:1878503424 DEBUG: Running thread 2968440832
06:27:32 T:2968440832 M:1878503424 DEBUG: thread start, auto delete: 0
06:27:32 T:2968440832 M:1878503424 NOTICE: Creating InputStream
06:27:32 T:2968440832 M:1862758400 DEBUG: CFileCache::Open - opening <zdf/data/msmedia/zdf/09/04/090426_videochat_kieling_tex_vh.wmv> using cache
06:27:33 T:2968440832 M:1862631424 DEBUG: MMS: socket connected
06:27:33 T:2968440832 M:1862492160 INFO: MMS: asf header packet detected, len=2486
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS: header read successful
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS: guid found: 6553200cc000e48e11cfa9478cabdca1
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS guid: file object, packet length = 8948 (8948)
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS: guid found: 6553200cc000e38e11cfa92e5fbf03b5
06:27:33 T:2968440832 M:1862483968 INFO: MMS guid: unknown object
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS: guid found: 50a85ec9a000f09711d2e307d2d0a440
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS: guid found: 6553200cc000e68e11cfa9b7b7dc0791
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS guid: stream object, stream_id=1
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS guid: stream object, stream_id=2
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS: guid found: b2a2c9976000828d11d1468d7bf875ce
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS: guid found: f64803c9a000a4a311d0311d86d15240
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS: guid found: 6cce6200aa00d9a611cf668e75b22633
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS: guid found: 6cce6200aa00d9a611cf668e75b22636
06:27:33 T:2968440832 M:1862483968 DEBUG: MMS guid: data object
06:27:34 T:2968440832 M:1862365184 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles
06:27:34 T:2968973312 M:1862365184 DEBUG: Running thread 2968973312
06:27:34 T:2968440832 M:1862365184 DEBUG: CacheSubtitles: START
06:27:34 T:2968973312 M:1862365184 DEBUG: thread start, auto delete: 0
06:27:34 T:2968440832 M:1862356992 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles done
06:27:34 T:2968440832 M:1862356992 NOTICE: Creating Demuxer
06:27:34 T:2968973312 M:1862270976 DEBUG: MMS: pre_header[0] = 01 (1)
06:27:34 T:2968973312 M:1862270976 DEBUG: MMS: pre_header[1] = 00 (0)
06:27:34 T:2968973312 M:1862270976 DEBUG: MMS: pre_header[2] = 00 (0)
06:27:34 T:2968973312 M:1862270976 DEBUG: MMS: pre_header[3] = 00 (0)
06:27:34 T:2968973312 M:1862270976 DEBUG: MMS: pre_header[4] = ce (206)
06:27:34 T:2968973312 M:1862270976 DEBUG: MMS: pre_header[5] = fa (250)
06:27:34 T:2968973312 M:1862270976 DEBUG: MMS: pre_header[6] = 0b (11)
06:27:34 T:2968973312 M:1862270976 DEBUG: MMS: pre_header[7] = b0 (176)
06:27:34 T:2968973312 M:1862254592 DEBUG: MMS: pre_header[0] = 00 (0)
06:27:34 T:2968973312 M:1862254592 DEBUG: MMS: pre_header[1] = 00 (0)
06:27:34 T:2968973312 M:1862254592 DEBUG: MMS: pre_header[2] = 00 (0)
06:27:34 T:2968973312 M:1862254592 DEBUG: MMS: pre_header[3] = 00 (0)
06:27:34 T:2968973312 M:1862254592 DEBUG: MMS: pre_header[4] = 04 (4)
06:27:34 T:2968973312 M:1862254592 DEBUG: MMS: pre_header[5] = 00 (0)
06:27:34 T:2968973312 M:1862254592 DEBUG: MMS: pre_header[6] = fa (250)
06:27:34 T:2968973312 M:1862254592 DEBUG: MMS: pre_header[7] = 22 (34)
06:27:34 T:2968973312 M:1862225920 DEBUG: MMS: pre_header[0] = 01 (1)
06:27:34 T:2968973312 M:1862225920 DEBUG: MMS: pre_header[1] = 00 (0)
06:27:34 T:2968973312 M:1862225920 DEBUG: MMS: pre_header[2] = 00 (0)
06:27:34 T:2968973312 M:1862225920 DEBUG: MMS: pre_header[3] = 00 (0)
06:27:34 T:2968973312 M:1862225920 DEBUG: MMS: pre_header[4] = 04 (4)
06:27:34 T:2968973312 M:1862225920 DEBUG: MMS: pre_header[5] = 01 (1)
06:27:34 T:2968973312 M:1862225920 DEBUG: MMS: pre_header[6] = f9 (249)
06:27:34 T:2968973312 M:1862225920 DEBUG: MMS: pre_header[7] = 22 (34)
06:27:34 T:2968440832 M:1862217728 INFO: Open - probing detected format [asf]
06:27:34 T:2968440832 M:1862201344 ERROR: Open - Error, could not open file mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/04/090426_videochat_kieling_tex_vh.wmv
06:27:34 T:2968440832 M:1862217728 ERROR: OpenDemuxStream - Error creating demuxer
06:27:34 T:2968440832 M:1862217728 NOTICE: CDVDPlayer::OnExit()
06:27:34 T:2968440832 M:1862217728 NOTICE: CDVDPlayer::OnExit() deleting input stream
06:27:34 T:2693658400 M:1862103040 DEBUG: ------------------- GUI_MSG_WINDOW_DEINIT
06:27:34 T:2693658400 M:1862103040 DEBUG: Progress dialog
06:27:34 T:2693658400 M:1862168576 ERROR: Playlist Player: skipping unplayable item: 0, path [mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/04/090426_videochat_kieling_tex_vh.wmv]
06:27:34 T:2693658400 M:1862168576 DEBUG: Playlist Player: no more playable items… aborting playback
06:27:34 T:2958389248 M:1862164480 DEBUG: Running thread 2958389248
06:27:34 T:2967375872 M:1862164480 DEBUG: Running thread 2967375872
06:27:34 T:2958389248 M:1862164480 DEBUG: thread start, auto delete: 0
06:27:34 T:2967375872 M:1862160384 DEBUG: thread start, auto delete: 0
06:27:34 T:2958389248 M:1862160384 DEBUG: staticThread, deleting thread graphic context
06:27:34 T:2967375872 M:1862160384 DEBUG: staticThread, deleting thread graphic context
06:27:34 T:2958389248 M:1862160384 DEBUG: Thread 2958389248 terminating
06:27:34 T:2967375872 M:1862160384 DEBUG: Thread 2967375872 terminating
06:27:34 T:2693658400 M:1862090752 NOTICE: CDVDPlayer::CloseFile()
06:27:34 T:2968973312 M:1862107136 DEBUG: staticThread, deleting thread graphic context
06:27:34 T:2968973312 M:1862086656 DEBUG: Thread 2968973312 terminating
06:27:34 T:2968440832 M:1877889024 DEBUG: Playback was stopped
06:27:34 T:2968440832 M:1877876736 DEBUG: staticThread, deleting thread graphic context
06:27:34 T:2968440832 M:1877876736 DEBUG: Thread 2968440832 terminating
06:27:34 T:2693658400 M:1877876736 NOTICE: DVDPlayer: waiting for threads to exit
06:27:34 T:2693658400 M:1877909504 NOTICE: DVDPlayer: finished waiting
06:27:34 T:2967908352 M:1877909504 DEBUG: staticThread, deleting thread object
06:27:34 T:2967908352 M:1877909504 DEBUG: staticThread, deleting thread graphic context
06:27:34 T:2967908352 M:1877909504 DEBUG: Thread 2967908352 terminating
06:28:00 T:2693658400 M:1880764416 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\ImageLib-osx.so)
06:28:00 T:2693658400 M:1880764416 DEBUG: Unloading: ImageLib-osx.so
06:28:00 T:2693658400 M:1880805376 INFO: CheckIdle - Closing session to http ://localhost (easy=0x1a9b7000, multi=0x1b44c680)
06:28:03 T:2693658400 M:1880043520 INFO: CheckIdle - Closing session to http ://ondemand.msmedia.zdf.newmedia.nacamar.net (easy=0x1b698000, multi=0x0)
06:28:32 T:2964713472 M:1872793600 NOTICE: ES: Client from 127.0.0.1 timed out
06:28:33 T:2693658400 M:1872564224 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\libcurl-osx.so)
06:28:33 T:2693658400 M:1872564224 DEBUG: Unloading: libcurl-osx.so
[/codebox]
to find out the difference between your setup and mine … I have send a PLEX-Report “rnio-stream-issue-05-2-09”
I also UPDATED the file at the WIKI to make sure you have 100% what I have.
BTW Thanks for taking your precious time to help me debug this … many Germans will be VERY thankful. At least THREE plug-in are affected by this.
This is RESOLVED with the new upcoming version 7.16
I tested it with 7.15.5 (pre-view Beta).
Thanks to the team :slight_smile: & elan :wink:
The next version is actually Plex/Eight, the first in our stable series :slight_smile:
