The buttons on the remote won't work (play/pause, FF, RW)
The status bar won't show the current play position. It only shows the bullet left in the beginning of the bar.
Anyway to correct that?
Try turning off the ATV’s subtitle language.
It sounds like it iOS bug that causes the progress bar to be white and the known fix is to have te ATV a subtitles language set to none
Wow!! Thank you very much! That did the trick…
Sent from my iPhone using Tapatalk
