I am really new to the PMS and stuff but it is totally amazing what you can do with it. For me PlexConnect is the best thing ever since I have several AppleTVs in my house.
Now to me question, since I got several ATV3's and I wanted to connect them all to me PMS thru PlexConnect I got a bit of a problem. After I successfully setup the first one. I started with the second one and it automaticly took the myPlex Username and Password from the first one. Don't know why that happend? So I left it like it was. Now when I start streaming Movie A on my first ATV and start streaming a Movie B on my second ATV. Pictures get mixed up!? This is my ATVSettings.cfg
PlexConnect is designed to be used only on the local network so you are running a configuration that is not supported (it isn’t great running the DNS part exposed to the world either as hackers will utilise it - not sure if you disabled this and are using your own locked down version). You do not have to have a local PMS though.
Maybe it is getting confused as your ATV devices will have the same IP when accessing over the WAN, even if if differentiates between the two the code is probably designed to send via IP address.
Did you -save .cfg, -stop PlexConnect, -restart it or -stop, - save, -restart?
Order is important, as shutting down would overwrite the current file.
Also, it's not the password getting saved, but the "myplex token" returned by myplex server. It somehow contains your password, but also other information, like device and so on...
Depends...
Thanks Baa ;)
I did -save .cfg - stop - start PlexConnect :( so i need to stop save start?
