Hello All,
I am running plexconnect with ATV3. Some of my movies do not have enough audio power that even with my speaker set up I am at max and still needing more volume. I changed the setting to transcode everything and then brought the audio boost to 125%. Helps alot, however, I have noticed that with the transcode, the video is great but the I am hearing alot of audio distortion, especially high pitched frequencies. I even tried turning off the audio boost, however I think it is a transcoding thing as it is still there. It does not happen with direct play. Has anyone else had this issue with the ATV3? I have the Fire TV and have not run into this issue. Is there a fix I can do on the ATV or Server side?
Thank you for the help and let me know if you need any additional info.
Running ATV3 with latest PlexConnect build
Server: Windows 7
