Server Version#: 1.18.1.1973
Player Version#: Web Client Version 4.8.3 & Tivo Bolt
When using the DVR, I have noticed that some recorded movies/shows are shown in the Plex client as “AC3 Stereo” and others are “AC3 5.1”. I have confirmed that my receiver is processing both as DD 5.1 as expected. The MediaInfo is also exactly the same. This is not a functional issue, but is kinda annoying in the UI.
Movie 1 (AC3 Stereo)
Audio #1
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 129
Duration : 2 h 14 min
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : -736 ms
Stream size : 371 MiB (6%)
Language : English
Service kind : Complete Main
Movie 2 (AC3 5.1)
Audio #1
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 2 h 4 min
Bit rate : 384 kb/s
Delay relative to video : -1 s 159 ms
Stream size : 343 MiB (4%)
Language : English
