Audio stream problem
Hi! I have a problem with dts autio stream .
It is work for some time, then sound disappears. I think it it because of audio codec converter. How i can solve this issue? See screen shot below Thanks
In above, you are transcoding DTS sound, since newer TV’s, Samsung included, doesn’t support DTS
Depending on your servers load, above could happen
So all I can suggest, is that you convert the audio tracks before playing, using like:
I’ve been having the same issue on several titles. All are direct playing. Only solve I found is to remux the files using handbreak
