Audio stutter when listening via Bluetooth in Tesla
When listening to music on my phone (OnePlus 10 Pro - Android 14) via Bluetooth in my car (Tesla MY 2023) with either the Plexamp or the Plex app, the audio stutters about every half a second. In some rare cases the music plays fine.
This is what I already tried:
  • Unpair and pair my phone to the car multiple times, had succes one time.
  • Switch between AAudio and OpenSL ES in the Plexamp app, no success.
  • Reboot the car OS, no success.
  • Change every Bluetooth codec related setting in the developer settings in multiple combinations, no success.
  • Reinstall my phone OS, no success.
  • Play some music from Spotify, YouTube and TuneIn, the music plays fine without stuttering.
  • An iPhone with the Plex and Plexamp apps, the music plays fine.
I’m curious if there is something else I could try and if someone experienced the same?
Server Version#: 1.40.2.8395
Plexamp app Version#: 4.10.1
Plex app Version#: 10.14.0.541
Hmm, unfortunately I’m not sure what to recommend here. You could try posting logs after it stutters for a bit, but I suspect the issue is somehow interwoven between android, bluetooth and the Tesla.
FWIW, I use iOS + Tesla M3 w/o issues, and others use Android + Bluetooth fine, so it’s just unclear what the difference here is…would be interesting to hear if anyone else has issues, I also suspect (just based on prior history) that using e.g. a Pixel wouldn’t have issues.
Thanks for your response! I have gathered the logs from Plexamp and I noticed a lot of lines that I think indicate the stutter. Unfortunately it’s not clear to me what the cause could be.
Sample:
May 22, 2024 08:31:20.127 [0x6d593cb0] WARNING - BASS: Mixer underflowed.
May 22, 2024 08:31:20.127 [0x6d593cb0] INFO - BASS: Mixer underflow ended.
May 22, 2024 08:31:20.725 [0x6d593cb0] WARNING - BASS: Mixer underflowed.
May 22, 2024 08:31:20.749 [0x6d593cb0] INFO - BASS: Mixer underflow ended.
May 22, 2024 08:31:21.225 [0x6d593cb0] WARNING - BASS: Mixer underflowed.
May 22, 2024 08:31:21.244 [0x6d593cb0] INFO - BASS: Mixer underflow ended.
May 22, 2024 08:31:21.725 [0x6d593cb0] WARNING - BASS: Mixer underflowed.
May 22, 2024 08:31:21.745 [0x6d593cb0] INFO - BASS: Mixer underflow ended.
698260529812954.zip (139.7 KB)
I gathered the logs from the normal Plex app as well. The messages are basically the same:
05-28 17:17:38.001  w: [Treble]: BASS: Mixer underflowed.
05-28 17:17:38.036  i: [Treble]: BASS: Mixer underflow ended.
05-28 17:17:38.497  w: [Treble]: BASS: Mixer underflowed.
05-28 17:17:38.527  i: [Treble]: BASS: Mixer underflow ended.
05-28 17:17:39.004  w: [Treble]: BASS: Mixer underflowed.
05-28 17:17:39.028  i: [Treble]: BASS: Mixer underflow ended.
Is it possible to change the buffer delay in the app(s)?
4_5958470853443195664.zip (284.5 KB)
Out of curiousity I also installed Jellyfin and that works fine too. So only the Plex apps seem to have trouble playing music over Bluetooth to the car.
Today I installed Tesla software version 2024.20.1 and I noticed that Bluetooth audio processing has much less delay now, playing and skipping songs almost instantly. That was certainly not the case before, taking about a second to notice the action (playing, pausing, skipping, etc.) in any app.
The Plex apps also play fine now and I do not see any mixer underflowed warnings in the debug logs anymore.
The delay problem was definitely in the Tesla software, but I also think that other apps could handle the delay better than the Plex apps. There is room for improvement there, but I understand that the urgency depends on how many similar cases of delay in bluetooth audio processing people experience daily (very likely not many :))
Keeping my fingers crossed, and so far I think we can safely say that the problem is solved for me.
