[BUG] Plexamp Android stuttering in background after period of time
Scenario:
Pixel 3a Android 12 Stock ROM
Playing music via WiFi connection for sometime, no problems.
Then starts to stutter badly ie it will play maybe a second or two, then pause for a number of seconds, then play again for a second or two, and repeats
Solution: Wake up the phone, but when screen goes off again the stuttering resumes
Note, I have disabled all battery optimisation for the app in Android
Logs attached
plexamp.zip (633.0 KB)
It really sounds like some sort of battery optimization or third party thing, there’s nothing suspicious in the logs. You can try switching audio interface to OpenSL from AAudio and see if it makes a difference.
OK its only happened the one time so far, I’ll see how I get on and look at the audio interface setting.
Thanks for checking the logs.
