Audio sync problem on DVR only
Is this common? Plex seems to record ok, but the audio just a second or two out of sync. Regular files (MP4) are playing fine, it’s just the ones recorded with the Plex DVR. Any way to fix this? Thanks.
I’m seeing the same thing. This is only an issue with DVR recordings.
Ok, thanks, at least it’s not just me. Maybe they will be able to fix it someday.
After more testing, my audio sync issues only happen on my Shield TV where the files are direct play. Anywhere it gets transcoded audio is perfectly in sync. Strange. I don’t have any problems with any movies or tv shows I have stored in .mkv containers.
