Audio track changes and playback crashes when opening the playback settings
My bad, I meant 02 instead of 00.
This is not working for me.
The problem is not fixed.
Can someone look into it, please ?
Here are new logs with a lower level of logging. The problem occured many times between 13h et 13h20.
No longer of use, I deleted my logs.
I confirm I also have the issue.
Hi all. Thanks for the reports and logs. We’ve identified the issue and are working on a fix.
That’s great to hear, thank you!
Thanks all for your patience, this should be fixed in the just released v1.62.2.
