Server Version#: 1.41.1.9057
Player Version#: 10.22.0.1579 (6a8017c9)
The Plex Player installed on my Sony 65A90J cannot play anything encoded with TrueHD.
The Playback Info shows:
Snips from the network logging page:
10-03 16:25:40.908 i: [device] Setting selected server to NUC13 version: 1.41.1.9057-af5eaea7a owned: true home: false videoTranscode: true audioTranscode: true deletion: false class: null, presence false
10-03 16:25:40.911 i: [ContentSectionNavigation] Navigating to path /hubs/sections/6
10-03 16:25:40.912 i: [ServerClaimingHelper] Server NUC13 cannot be claimed: it doesn't have required conditions
10-03 16:25:40.924 i: [Boot] g took 2ms to run create behaviours.
10-03 16:25:40.948 i: Fetching [method:GET] https://10.27.0.50:32400/hubs/sections/6?count=25&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CLabel%2CMood%2CPart%2CPhoto%2CProducer%2CSimilar%2CTopic%2CVast%2CWriter&excludeFields=file%2Ctagline&includeDetails=1&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...AtzQ&X-Plex-Language=en-gb
10-03 16:25:41.015 i: [SectionHubManager] Notifying listeners with status: SUCCESS
10-03 16:25:42.222 i: [ActivityBackgroundBehaviour] Canceling Playback: Changing background.
10-03 16:25:44.505 i: [ContentSectionNavigation] Navigating to path /library/sections/6/all?type=1
10-03 16:25:44.507 i: [ServerClaimingHelper] Server NUC13 cannot be claimed: it doesn't have required conditions
10-03 16:25:44.522 i: [Boot] g took 2ms to run create behaviours.
10-03 16:25:44.542 i: Fetching section details from /library/sections/6/all?type=1
10-03 16:25:44.552 i: Fetching [method:GET] https://10.27.0.50:32400/library/sections/6/all?includeAdvanced=1&includeMeta=1&type=1&X-Plex-Container-Size=0&X-Plex-Container-Start=0&X-Plex-Token=...AtzQ&X-Plex-Language=en-gb
10-03 16:25:44.560 i: [ActivityBackgroundBehaviour] Canceling Playback: Changing background.
10-03 16:25:44.583 i: [ContentSectionDelegate] setInitialSecondaryFilter for Movies 4K • NUC13, filter: com.plexapp.plex.net.k5@2e03d79
10-03 16:25:44.584 i: [ContentSectionDelegate] generateAndApplyQuery for Movies 4K • NUC13
10-03 16:25:44.610 i: Fetching [method:GET] https://10.27.0.50:32400/library/sections/6/all?includeCollections=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&sort=titleSort&type=1&X-Plex-Token=...AtzQ&X-Plex-Container-Start=0&X-Plex-Container-Size=24&X-Plex-Language=en-gb
10-03 16:25:44.621 i: [BaseSectionFragment] Initializing sorts and filters.
10-03 16:25:44.642 i: [Jump letter] Updating visibility of jump letter: (true)
10-03 16:25:44.653 i: Fetching [method:GET] https://10.27.0.50:32400/library/sections/6/firstCharacter?includeCollections=1&IncludeExternalMedia=1&sort=titleSort&X-Plex-Token=...AtzQ&X-Plex-Language=en-gb
10-03 16:25:44.674 i: [BaseSectionFragment] Updated column count: (6)
10-03 16:25:44.716 i: Fetching [method:GET] https://10.27.0.50:32400/library/sections/6/all?includeCollections=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&sort=titleSort&type=1&X-Plex-Token=...AtzQ&X-Plex-Container-Start=24&X-Plex-Container-Size=24&X-Plex-Language=en-gb
10-03 16:25:47.285 i: [ActivityBackgroundBehaviour] Canceling Playback: Changing background.
10-03 16:25:48.093 i: [ActivityBackgroundBehaviour] Canceling Playback: Changing background.
10-03 16:25:48.392 i: [ActivityBackgroundBehaviour] Canceling Playback: Changing background.
10-03 16:25:49.376 i: [PreplaySectionModelManager] Observing preferred platforms
10-03 16:25:49.412 i: [ActivityBackgroundBehaviour] Canceling Playback: Changing background.
10-03 16:25:49.424 i: [PreplayLocationsViewModel] Observing preferred platforms
10-03 16:25:50.398 i: [Preplay] Notifying listeners with status: SUCCESS
10-03 16:25:50.400 i: [Preplay] Notifying listeners with status: SUCCESS
10-03 16:25:50.441 i: Fetching [method:GET] https://10.27.0.50:32400/library/metadata/26442/related?count=25&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CLabel%2CMood%2CPart%2CPhoto%2CProducer%2CSimilar%2CTopic%2CVast%2CWriter&excludeFields=file%2Ctagline&includeAugmentations=1&includeDetails=1&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...AtzQ&X-Plex-Language=en-gb
10-03 16:25:50.903 i: [Preplay] Notifying listeners with status: SUCCESS
10-03 16:25:50.904 i: [Preplay] Notifying listeners with status: SUCCESS
10-03 16:25:50.908 i: [Preplay] Notifying listeners with status: SUCCESS
10-03 16:25:50.914 i: [Preplay] Notifying listeners with status: SUCCESS
10-03 16:25:50.915 i: [Preplay] Notifying listeners with status: SUCCESS
10-03 16:25:50.941 i: Fetching [method:GET] https://10.27.0.50:32400/library/augmentation/26442/relatedAlbums?count=25&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CLabel%2CMood%2CPart%2CPhoto%2CProducer%2CSimilar%2CTopic%2CVast%2CWriter&excludeFields=file%2Ctagline&includeDetails=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&indirectMedia=1&libraryHubsOnly=1&X-Plex-Token=...AtzQ&X-Plex-Language=en-gb
10-03 16:25:51.046 i: Fetching [method:GET] https://10.27.0.50:32400/library/augmentation/26442/relatedTracks?count=25&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CLabel%2CMood%2CPart%2CPhoto%2CProducer%2CSimilar%2CTopic%2CVast%2CWriter&excludeFields=file%2Ctagline&includeDetails=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&indirectMedia=1&libraryHubsOnly=1&X-Plex-Token=...AtzQ&X-Plex-Language=en-gb
10-03 16:26:00.558 i: [OneApp] User can execute command without restrictions because they are entitled.
10-03 16:26:00.563 i: [PlaybackManager] Preparing for Avengers: Endgame
10-03 16:26:00.566 i: [VideoUtils] MediaCodec found (OMX.MTK.VIDEO.DECODER.AV1) for video/av01
10-03 16:26:00.567 i: [VideoUtils] MediaCodec found (OMX.MTK.VIDEO.DECODER.AVC) for video/avc
10-03 16:26:00.568 i: [VideoUtils] MediaCodec found (OMX.MTK.VIDEO.DECODER.HEVC) for video/hevc
10-03 16:26:00.570 i: [VideoUtils] MediaCodec found (OMX.dolby.vision.dvhe.stn.decoder) for video/dolby-vision
10-03 16:26:00.571 i: [VideoUtils] MediaCodec found (OMX.MTK.VIDEO.DECODER.MPEG2) for video/mpeg2
10-03 16:26:00.572 i: [VideoUtils] MediaCodec found (OMX.MTK.VIDEO.DECODER.MPEG4) for video/mp4v-es
10-03 16:26:00.573 i: [VideoUtils] MediaCodec found (OMX.MTK.VIDEO.DECODER.VP8) for video/x-vnd.on2.vp8
10-03 16:26:00.574 i: [VideoUtils] MediaCodec found (OMX.MTK.VIDEO.DECODER.VP9) for video/x-vnd.on2.vp9
10-03 16:26:00.576 i: [MediaCodecCaps] Support detected: (audio/raw, Max: 8)
10-03 16:26:00.577 i: [MediaCodecCaps] Support detected: (audio/mpeg-L1, Max: 1)
10-03 16:26:00.577 i: [MediaCodecCaps] Support detected: (audio/mpeg-L2, Max: 1)
10-03 16:26:00.579 i: [MediaCodecCaps] Support detected: (audio/mpeg, Max: 2)
10-03 16:26:00.579 i: [MediaCodecCaps] Support detected: (audio/ac3, Max: 6)
10-03 16:26:00.579 i: [MediaCodecCaps] Support detected: (audio/eac3, Max: 16)
10-03 16:26:00.581 i: [MediaCodecCaps] Support detected: (audio/vnd.dts, Max: 1)
10-03 16:26:00.581 i: [MediaCodecCaps] Support detected: (audio/vnd.dts.hd, Max: 1)
10-03 16:26:00.582 i: [MediaCodecCaps] Support detected: (audio/true-hd, Max: 1)
10-03 16:26:00.587 i: [PlaybackManager] Audio codec required: truehd
10-03 16:26:00.587 i: [DefaultPlaybackManager] No codecs being downloaded.
10-03 16:26:00.593 i: [PlayQueues] Creating delayed remote PQ.
10-03 16:26:00.616 i: [PlayerService] Service has been created.
10-03 16:26:00.621 i: [PlayerService] Service is being initialised.
10-03 16:26:00.623 i: [ConnectivityManager] Device is under Ethernet
10-03 16:26:00.624 i: [Player] Changing to use ExoPlayer for playback.
10-03 16:26:00.642 i: [LoadControl] Setting buffer size to 73.19 MB / 0 seconds.
10-03 16:26:00.657 i: [ExoPlayer][ExoPlayerImpl] Init 526a338 [AndroidXMedia3/1.1.0] [BRAVIA_VH2, BRAVIA 4K VH2, Sony, 29]
10-03 16:26:00.663 i: [AudioCapabilitiesHelper] Passthrough is set to auto over HDMI, supported capabilities:
10-03 16:26:00.664 i: [AudioCapabilitiesHelper] - ac3
10-03 16:26:00.664 i: [AudioCapabilitiesHelper] - eac3
10-03 16:26:00.664 i: [AudioCapabilitiesHelper] - dca
10-03 16:26:00.665 i: [AudioCapabilitiesHelper] - dca
10-03 16:26:00.676 i: [ExoPlayerEngine] Constructed ExoPlayer to use a background looper.
10-03 16:26:00.733 i: [MemoryOptimisationBehaviour] Reducing memory cache.
10-03 16:26:00.738 i: [PictureInPictureBehaviour] Picture-in-picture unavailable as the activity is missing.
10-03 16:26:00.742 i: [MediaSessionHelper] Releasing media session with tag: music
10-03 16:26:00.749 i: [MediaSessionHelper] Starting media session with tag: video
10-03 16:26:00.750 i: [MediaSessionHelper] Creating media session with tag: video
10-03 16:26:00.773 i: [CurrentItemMetadataBehaviour] Fetching current item
10-03 16:26:00.775 i: [MediaSessionBehaviour] Current item has changed
10-03 16:26:00.777 i: [MediaSessionBehaviour] Updating metadata for video.
10-03 16:26:00.783 i: [InteractionBehaviour] Slept, reason: Startup.
10-03 16:26:00.789 i: [PlayerService] Service has been started successfully.
10-03 16:26:00.804 i: [ExoPlayer][EventLogger] surfaceSize [eventTime=0.13, mediaPos=0.00, window=0, 0, 0]
10-03 16:26:00.806 i: [Player][ExoPlayer] Setting given surfaceView
10-03 16:26:00.809 i: [VideoAwakeBehaviour] Keep screen awake has been requested disabled for VideoAwakeBehaviour.
10-03 16:26:00.813 i: [DisplayBehaviour] New ExoPlayerEngine detected, enabling: true.
10-03 16:26:00.814 i: [Player][ExoPlayer] Using PlayQueueMediaSource
10-03 16:26:00.816 i: [ExoPlayerEngine] Media source has been created.
10-03 16:26:00.816 i: [MediaCodecVideoSyncRenderer] Setting allow dummy surface: false
10-03 16:26:00.820 i: [LoadControl] Setting buffer size to 73.19 MB / 0 seconds.
10-03 16:26:00.822 i: [ExoPlayer][EventLogger] playWhenReady [eventTime=0.14, mediaPos=0.00, window=0, true, USER_REQUEST]
10-03 16:26:00.826 i: [ExoPlayer][EventLogger] timeline [eventTime=0.15, mediaPos=0.00, window=0, periodCount=1, windowCount=1, reason=PLAYLIST_CHANGED
10-03 16:26:00.827 i: [ExoPlayer][EventLogger] period [?]
10-03 16:26:00.828 i: [ExoPlayer][EventLogger] window [?, seekable=false, dynamic=true]
10-03 16:26:00.828 i: [ExoPlayer][EventLogger] ]
10-03 16:26:00.830 i: [Player][ExoPlayer] onTimelineChanged (Position: 0 ms, Duration: 0 ms)
10-03 16:26:00.832 i: [ExoPlayer][EventLogger] mediaItem [eventTime=0.15, mediaPos=0.00, window=0, reason=PLAYLIST_CHANGED]
10-03 16:26:00.833 i: [LoadControl] Setting buffer size to 73.19 MB / 0 seconds.
10-03 16:26:00.835 i: [ExoPlayer][EventLogger] state [eventTime=0.16, mediaPos=0.00, window=0, BUFFERING]
10-03 16:26:00.842 i: [MediaDecisionEngine] Starting media decision for: Avengers: Endgame (part index 0)
10-03 16:26:00.847 i: [MediaDecisionEngine] Transcode server selected: NUC13
10-03 16:26:00.851 i: [MediaDecisionEngine] Analyzing media: 3840x2160 48497kbps (Container: mkv, Video: hevc, Audio: truehd)
10-03 16:26:00.869 i: [MediaDecisionEngine] Unable to direct play; TrueHD audio is not supported by the device
10-03 16:26:00.877 i: Creating PlayerActivity.
10-03 16:26:00.878 i: [Activity] Resuming the application, attempting to download item and children.
10-03 16:26:00.880 i: [Boot] PlayerActivity took 3ms to run create behaviours.
10-03 16:26:00.897 i: [video] User maximum h264 profile determined: 52
10-03 16:26:00.898 i: [video] Device recommended h264 profile determined: 52
10-03 16:26:00.899 i: Resuming PlayerActivity.
10-03 16:26:00.901 i: [PlayerActivity] Creating fragment
10-03 16:26:00.914 i: [Player][DimensionsLayout] Resizing: 100 x 100
10-03 16:26:00.927 i: [DisplayBehaviour] Activity has been changed, searching for available modes.
10-03 16:26:00.933 i: [DisplayBehaviour] Current Mode ID: 1 / {id=1, width=1920, height=1080, fps=60.000004}
10-03 16:26:00.934 i: [DisplayBehaviour] Current mode detected as 1920x1080 @ 60.0000Hz (1).
10-03 16:26:00.943 i: [PictureInPictureBehaviour] Picture-in-picture is available and can be used.
10-03 16:26:00.947 i: [VideoAwakeBehaviour] Keep screen awake has been requested disabled for VideoAwakeBehaviour.
10-03 16:26:01.139 i: [PictureInPictureBehaviour] Picture-in-picture is available and can be used.
10-03 16:26:01.143 i: [PictureInPictureBehaviour] Picture-in-picture is available and can be used.
10-03 16:26:01.168 i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
10-03 16:26:01.169 i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
10-03 16:26:01.169 i: [BufferHelper] Segment count: 3276
10-03 16:26:01.177 i: [PictureInPictureBehaviour] Picture-in-picture is available and can be used.
10-03 16:26:01.192 i: [ChaptersSheetHud] Found 0 chapters.
10-03 16:26:01.216 i: [MenuSheetHud] Item changed (and fetched), invalidating settings...
10-03 16:26:01.224 i: Fetching [method:GET] https://10.27.0.50:32400/video/:/transcode/universal/decision?audioBoost=180&autoAdjustQuality=0&autoAdjustSubtitle=1&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F26442&protocol=*&session=f85ed531a2121f22-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160&X-Plex-Client-Identifier=f85ed531a2121f22-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D52)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26container%3Dmkv%26videoCodec%3Dh264%2Chevc%2Cmpeg2video%26audioCodec%3Daac%2Cac3%2Cdca%2Cdca%2Cdca%2Ceac3%2Cmp3%2Cwmav1%2Cwmav2%2Cwmalossless%2Cwmapro%2Cwmavoice%26subtitleCodec%3Dass%2Cpgs%2Csubrip%2Cdvd_subtitle%2Cmov_text%2Cvtt%2Cdvb_subtitle%26replace%3Dtrue)%2Badd-transcode-target-settings(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26CopyMatroskaAttachments%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain%7Cmain%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084%7Cbt709%7Cbt470m%7Csmpte240m%7Csmpte170m%7Cbt470bg%7Cbt2020-10%26isRequired%3Dfalse)&X-Plex-Device=BRAVIA%204K%20VH2&X-Plex-Platform=Android&X-Plex-Platform-Version=10&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Session-Id=81083947-8f1a-47f7-acc6-83d7952fac13&X-Plex-Version=10.22.0.1579&X-Plex-Token=...AtzQ&X-Plex-Language=en-gb
10-03 16:26:01.260 i: [MediaDecisionEngine] Server was happy with client's original decision
10-03 16:26:01.261 i: [MediaDecisionEngine] Decision: CanPlay: true CanDirectPlay: false CanDirectStreamVideo: true CanDirectStreamAudio: false CanDirectPlaySubtitle: false CanTranscodeSubtitle: false CanDisplayVideo: true Transcode Reason: TrueHD audio is not supported by the device
10-03 16:26:01.264 i: [LoadControl] New bitrate: 200000, Maximum: 200000
10-03 16:26:01.265 i: [MediaDecisionMediaSource] Resetting mappable types.
10-03 16:26:01.267 i: [video] User maximum h264 profile determined: 52
10-03 16:26:01.271 i: [video] Device recommended h264 profile determined: 52
10-03 16:26:01.279 i: [CurrentItemMetadataBehaviour] Fetched current item, success: true
10-03 16:26:01.281 i: [ChaptersSheetHud] Found 21 chapters.
10-03 16:26:01.282 i: [MenuSheetHud] Item changed (and fetched), invalidating settings...
10-03 16:26:01.461 i: [Player][View] Layout has been measured with a size of 1920 x 1080 (1920 x 1080).
10-03 16:26:01.466 i: [Player][DimensionsLayout] Resizing: 1920 x 1080
10-03 16:26:01.477 i: [ASS][Renderer] Surface has been created, connecting to renderer.
10-03 16:26:01.502 i: [SystemUIBehaviour] Hiding the system user-interface.
10-03 16:26:01.571 i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
10-03 16:26:01.571 i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
10-03 16:26:01.572 i: [BufferHelper] Segment count: 3276
10-03 16:26:01.574 i: [MediaDecisionMediaSource] Loading from https://10-27-0-50.5ce9af6bc4604250b5ead29c907225b9.plex.direct:32400/video/:/transcode/universal/start.m3u8?audioBoost=180&autoAdjustQuality=0&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F26442&protocol=hls&session=f85ed531a2121f22-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160&X-Plex-Client-Identifier=f85ed531a2121f22-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D52)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26container%3Dmkv%26videoCodec%3Dh264%2Chevc%2Cmpeg2video%26audioCodec%3Daac%2Cac3%2Cdca%2Cdca%2Cdca%2Ceac3%2Cmp3%2Cwmav1%2Cwmav2%2Cwmalossless%2Cwmapro%2Cwmavoice%26subtitleCodec%3Dass%2Cpgs%2Csubrip%2Cdvd_subtitle%2Cmov_text%2Cvtt%2Cdvb_subtitle%26replace%3Dtrue)%2Badd-transcode-target-settings(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26CopyMatroskaAttachments%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain%7Cmain%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084%7Cbt709%7Cbt470m%7Csmpte240m%7Csmpte170m%7Cbt470bg%7Cbt2020-10%26isRequired%3Dfalse)&X-Plex-Device=BRAVIA%204K%20VH2&X-Plex-Platform=Android&X-Plex-Platform-Version=10&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Session-Id=81083947-8f1a-47f7-acc6-83d7952fac13&X-Plex-Token=...AtzQ&X-Plex-Version=10.22.0.1579.
10-03 16:26:01.574 i: [video] User maximum h264 profile determined: 52
10-03 16:26:01.575 i: [video] Device recommended h264 profile determined: 52
10-03 16:26:01.732 i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
10-03 16:26:01.733 i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
10-03 16:26:01.733 i: [BufferHelper] Segment count: 3276
10-03 16:26:01.735 i: [MediaDecisionMediaSource] Loading from https://10.27.0.50:32400/video/:/transcode/universal/start.m3u8?audioBoost=180&autoAdjustQuality=0&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F26442&protocol=hls&session=f85ed531a2121f22-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160&X-Plex-Client-Identifier=f85ed531a2121f22-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D52)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26container%3Dmkv%26videoCodec%3Dh264%2Chevc%2Cmpeg2video%26audioCodec%3Daac%2Cac3%2Cdca%2Cdca%2Cdca%2Ceac3%2Cmp3%2Cwmav1%2Cwmav2%2Cwmalossless%2Cwmapro%2Cwmavoice%26subtitleCodec%3Dass%2Cpgs%2Csubrip%2Cdvd_subtitle%2Cmov_text%2Cvtt%2Cdvb_subtitle%26replace%3Dtrue)%2Badd-transcode-target-settings(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26CopyMatroskaAttachments%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain%7Cmain%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084%7Cbt709%7Cbt470m%7Csmpte240m%7Csmpte170m%7Cbt470bg%7Cbt2020-10%26isRequired%3Dfalse)&X-Plex-Device=BRAVIA%204K%20VH2&X-Plex-Platform=Android&X-Plex-Platform-Version=10&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Session-Id=81083947-8f1a-47f7-acc6-83d7952fac13&X-Plex-Token=...AtzQ&X-Plex-Version=10.22.0.1579.
10-03 16:26:01.736 i: [MediaDecisionMediaSource] Resolving 10-27-0-50.5ce9af6bc4604250b5ead29c907225b9.plex.direct as 10.27.0.50.
10-03 16:26:01.737 i: [AudioCapabilitiesHelper] Passthrough is set to auto over HDMI, supported capabilities:
10-03 16:26:01.737 i: [AudioCapabilitiesHelper] - ac3
10-03 16:26:01.738 i: [AudioCapabilitiesHelper] - eac3
10-03 16:26:01.738 i: [AudioCapabilitiesHelper] - dca
10-03 16:26:01.739 i: [AudioCapabilitiesHelper] - dca
10-03 16:26:01.740 i: [MediaDecisionMediaSource] Opening https://10-27-0-50.5ce9af6bc4604250b5ead29c907225b9.plex.direct:32400/video/:/transcode/universal/start.m3u8?audioBoost=180&autoAdjustQuality=0&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F26442&protocol=hls&session=f85ed531a2121f22-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160&X-Plex-Client-Identifier=f85ed531a2121f22-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D52)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26container%3Dmkv%26videoCodec%3Dh264%2Chevc%2Cmpeg2video%26audioCodec%3Daac%2Cac3%2Cdca%2Cdca%2Cdca%2Ceac3%2Cmp3%2Cwmav1%2Cwmav2%2Cwmalossless%2Cwmapro%2Cwmavoice%26subtitleCodec%3Dass%2Cpgs%2Csubrip%2Cdvd_subtitle%2Cmov_text%2Cvtt%2Cdvb_subtitle%26replace%3Dtrue)%2Badd-transcode-target-settings(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26CopyMatroskaAttachments%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain%7Cmain%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084%7Cbt709%7Cbt470m%7Csmpte240m%7Csmpte170m%7Cbt470bg%7Cbt2020-10%26isRequired%3Dfalse)&X-Plex-Device=BRAVIA%204K%20VH2&X-Plex-Platform=Android&X-Plex-Platform-Version=10&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Session-Id=81083947-8f1a-47f7-acc6-83d7952fac13&X-Plex-Token=...AtzQ&X-Plex-Version=10.22.0.1579.
10-03 16:26:01.742 i: [MediaDecisionMediaSource] Using HlsMediaSource with FFmpegExtractor.
10-03 16:26:01.742 i: [MediaDecisionMediaSource] onMediaDecisionRefreshed (Sources: 1)
10-03 16:26:01.743 i: [DisplayBehaviour] Mode found: 1920x1080 @ 60.0000Hz (1) (Score: 125.00 (RR: 0.00 R: 125.00)
10-03 16:26:01.744 i: [DisplayBehaviour] Best mode for 1920x1080 @ 23.976000Hz selected as 1920x1080 @ 60.0000Hz (1).
10-03 16:26:01.745 i: [DisplayBehaviour] Current Mode ID: 1 / {id=1, width=1920, height=1080, fps=60.000004}
10-03 16:26:01.745 i: [DisplayBehaviour] Mode is already set to our best mode of 1920x1080 @ 60.0000Hz (1).
10-03 16:26:01.746 i: [ExoPlayer][EventLogger] surfaceSize [eventTime=1.07, mediaPos=0.00, window=0, period=0, 1920, 1080]
10-03 16:26:02.086 i: [ASS][Renderer] Attempting to start renderer from setSurface.
10-03 16:26:02.230 w: [ASS][Renderer] Missing video size, can't start renderer yet.
10-03 16:26:53.681 i: [HttpServer] /10.27.2.14:53432 - GET /logging
10-03 16:27:19.935 i: [Player] Engine being destroyed due to player deconstruction.
10-03 16:27:19.936 i: [Player] Starting to clear huds on player destroy. Activity finishing: false, should finish activity: true
10-03 16:27:19.937 i: [ExoPlayerEngine] Releasing media source due to engine destruction.
10-03 16:27:19.941 i: [ExoPlayer][EventLogger] state [eventTime=79.26, mediaPos=0.00, window=0, period=0, IDLE]
10-03 16:27:19.941 i: [ExoPlayer][ExoPlayerImpl] Release 526a338 [AndroidXMedia3/1.1.0] [BRAVIA_VH2, BRAVIA 4K VH2, Sony, 29] [media3.common, media3.exoplayer, media3.decoder, media3.exoplayer.hls, media3.datasource]
10-03 16:27:19.942 i: [MemoryOptimisationBehaviour] Expanding memory cache.
10-03 16:27:19.942 i: [VideoAwakeBehaviour] Keep screen awake has been requested disabled for VideoAwakeBehaviour.
10-03 16:27:19.943 i: [AudioFocusBehaviour] Behaviour being destroyed, giving up audio focus
10-03 16:27:19.949 i: [LoadControl] Setting buffer size to 73.19 MB / 0 seconds.
10-03 16:27:19.950 i: [DisplayBehaviour] Reverting back to the original display mode.
10-03 16:27:19.950 i: [LoadControl] Setting buffer size to 73.19 MB / 0 seconds.
10-03 16:27:19.955 i: [DisplayBehaviour] Current Mode ID: 1 / {id=1, width=1920, height=1080, fps=60.000004}
10-03 16:27:19.956 i: [DisplayBehaviour] Mode is already set to our best mode of 1920x1080 @ 60.0000Hz (1).
10-03 16:27:19.965 i: [MediaSessionBehaviour] Releasing MediaSessionHelper
10-03 16:27:19.965 i: [MediaSessionHelper] Releasing media session with tag: video
10-03 16:27:19.976 i: [PlayerService] Terminating service from stop request.
10-03 16:27:19.994 i: [PlayerService] Service been destroyed.
10-03 16:27:20.020 i: [ActivityBackgroundBehaviour] Canceling Playback: Starting new playback from onStart.
10-03 16:27:20.023 i: Resuming HomeActivityTV.
10-03 16:27:20.532 i: [ASS][Renderer] Surface has been destroyed, disconnecting.
10-03 16:27:20.534 w: [ExoPlayer][ExoPlayerImplInternal] Ignoring messages sent after release.
10-03 16:27:20.559 i: [Player] Starting to clear huds on view detach. Activity finishing: null
10-03 16:27:23.624 i: [ActivityBackgroundBehaviour] Canceling Playback: Stopping playback from onStop.
10-03 16:27:23.698 i: [WebSocketApplicationBehaviour] Focus change detected. Focused: false
10-03 16:27:23.705 i: [AndroidHomeContentBehaviour] Updating channels with reason: FOCUS_LOST
10-03 16:27:23.714 i: [HomeHubsManager] Discovering. Force: false. Partial: false. Reason: recommendations
10-03 16:27:23.716 i: [DynamicHome] Reusing results from previous discovery.
10-03 16:27:23.730 i: [DynamicHome] Not starting new discovery task because previous one was equivalent.
