SOLVED Cannot Direct Stream on Samsung MU6100
SOLVED see below.
Server Version#: 1.24.5.5173
Player Version#: 5.27.3
During 2020 and part of 2021 I could playback TrueHD 7.1 mkv files just fine but last days these movies that played ok try to do a full transcode from HEVC to H264. Obviously this is a bug as my TV has Dash protocol and it was able to just transcode the audio stream to AC3 and playback just fine. Now the truehd audio tries to transcode but in the end it just tries to transcode the full movie, failing in the process and cancelling the playback.
I’m really frustrated that without doing anything Plex just starts failing, I mean my playback with this TV was seamless and I was glad that I didn’t have the issues I had with my Chromecast, or with my new Samsung TV that doesn’t support dash and DTS. This TV worked flawlessly and now its failing just like anything else that has a Plex app and its not a Nvidia Shield.
Please let me know how can I rollback the Plex version from my Samsung please.
Logs:
Nov 21, 2021 17:13:18.246 [0x7fc86f99bb38] DEBUG - [Transcode] It took 0.000000 ms to retrieve 103 items.
Nov 21, 2021 17:13:18.251 [0x7fc86f99bb38] DEBUG - [Transcode] It took 0.000000 ms to retrieve 103 items.
Nov 21, 2021 17:13:18.252 [0x7fc86f99bb38] DEBUG - [Transcode] Audio Stream: 1557, Subtitle Stream: 0
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] Scaled up video bitrate to 158373Kbps based on 4.500000x fudge factor.
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: Selected protocol dash; container: mp4
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: analyzing media item 600
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: The Matrix (1999): Direct Play is disabled
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: The Matrix (1999): media must be transcoded in order to use the dash protocol
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: The Matrix (1999): no direct play video profile exists for http/mkv/hevc
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: The Matrix (1999): no direct play video profile exists for http/mkv/hevc/truehd
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: The Matrix (1999): no direct play video profile exists for http/mkv/hevc/ac3
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: The Matrix (1999): Direct Streaming is disabled, so video stream will be transcoded
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: The Matrix (1999): no remuxable profile found, so video stream will be transcoded
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: The Matrix (1999): Audio Direct Streaming is disabled, so video’s audio stream will be transcoded
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: Cannot direct stream audio stream due to profile or setting limitations
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] MDE: The Matrix (1999): selected media 0 / 600
Nov 21, 2021 17:13:18.254 [0x7fc86f99bb38] DEBUG - [Transcode] Streaming Resource: Reached Decision id=280 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=4002,Not enough CPU for conversion of this item.)
Nov 21, 2021 17:13:18.255 [0x7fc86f746b38] DEBUG - Completed: [172.20.0.12:46074] 200 GET /video/:/transcode/universal/decision?directPlay=0&directStream=0&directStreamAudio=0&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F280&session=bh9obpobviox0f6rip3lgi1e&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=125&videoQuality=100&videoResolution=4096x2160&audioBoost=700&location=wan (6 live) GZIP 17ms 693 bytes (pipelined: 6)
Nov 21, 2021 17:13:22.252 [0x7fc86f99bb38] DEBUG - Request: [127.0.0.1:60948 (Loopback)] GET /identity (7 live) Signed-in
Nov 21, 2021 17:13:22.252 [0x7fc86f746b38] DEBUG - Completed: [127.0.0.1:60948] 200 GET /identity (7 live) 0ms 398 bytes (pipelined: 1)
Nov 21, 2021 17:13:22.351 [0x7fc86f839b38] DEBUG - WebSocket: client initiated close
Nov 21, 2021 17:13:22.351 [0x7fc86f746b38] DEBUG - handleStreamRead code 2: End of file
Nov 21, 2021 17:13:22.351 [0x7fc86f746b38] DEBUG - NotificationStream: Removing because of error
Nov 21, 2021 17:13:22.351 [0x7fc86f746b38] DEBUG - Completed after connection close: [172.20.0.12:45624] -3 GET /:/websockets/notifications?filters=log (6 live) GZIP 35367ms 115276 bytes
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] DEBUG - Request: [172.20.0.12:46074 (Subnet)] POST /log (5 live) GZIP Signed-in Token (dantebarba)
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] ERROR - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] [AVPlay[1] (IDLE)] onAVPlayError: PLAYER_ERROR_NOT_SUPPORTED_FILE
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] [PlaybackSessionController] playback state changed to: stopped
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] WARN - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] Failed to send transcode action stop to source: server://9985e45e37630e537bd3cbf4cf47230b5fbe117d/com.plexapp.plugins.library/library/metadata/280
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] ERROR - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] Playback error occurred. Reason: UnsupportedFileOrFormat, Player does not support file or format
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] WARN - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] [PlaybackSessionController] able to retry playback, {
“metadataSourceUri”: “server://9985e45e37630e537bd3cbf4cf47230b5fbe117d/com.plexapp.plugins.library/library/metadata/280”,
“retries”: 1,
“allowDirectPlay”: false,
“allowDirectStream”: false
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] [AVPlay[1] (IDLE)] setListener ({})
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] [AVPlay[1] (IDLE)] close ()
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] [AVPlayFactory] Destroying player [1]…
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] [MDE] Application decision, directPlay: false, directStreamVideo: false, directStreamAudio: false
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] Cannot direct play with protocol: http, codec: truehd. Not found in profile.
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] Cannot direct stream with protocol: dash, codec: truehd. Not found in profile.
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] Application disabled direct play.
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] Application disabled direct stream.
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] videoStream: {
“id”: 1556,
“streamType”: 1,
“default”: true,
“codec”: “hevc”,
“index”: 0,
“bitrate”: 35194,
“bitDepth”: 10,
“chromaSubsampling”: “4:2:0”,
“codedHeight”: 1600,
“codedWidth”: 3840,
“colorPrimaries”: “bt2020”,
“colorRange”: “tv”,
“colorSpace”: “bt2020nc”,
“colorTrc”: “smpte2084”,
“frameRate”: 23.976,
“height”: 1600,
“level”: 153,
“profile”: “main 10”,
“refFrames”: 1,
“width”: 3840,
“displayTitle”: “4K (HEVC Main 10 HDR)”,
“extendedDisplayTitle”: “4K (HEVC Main 10 HDR)”
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] audioStream: {
“id”: 1557,
“streamType”: 2,
“selected”: true,
“default”: true,
“codec”: “truehd”,
“index”: 1,
“channels”: 8,
“bitrate”: 4420,
“language”: “Inglés”,
“languageTag”: “en”,
“languageCode”: “eng”,
“audioChannelLayout”: “7.1”,
“bitDepth”: 24,
“samplingRate”: 48000,
“title”: “Atmos 7.1”,
“displayTitle”: “Inglés (TRUEHD 7.1)”,
“extendedDisplayTitle”: “Atmos 7.1 (Inglés TRUEHD)”
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] INFO - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] subtitleStream: none
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] WARN - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] Failed to reevaluate current playable!
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] WARN - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] [PlaybackSessionController] we failed to create a playable URL!
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] ERROR - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] Playback error occurred. Reason: FailedToCreatePlayable, Failed to create a playable with the current play queue item! Message: General: Direct Play o Conversión no disponibles. Direct: La aplicación no puede reproducir directamente este elemento. La reproducción directa está deshabilitada. Transcode: No hay CPU suficiente para convertir este elemento.
Nov 21, 2021 17:13:22.786 [0x7fc86e48cb38] WARN - [Plex for Samsung] [dantebarba:cnhxlruc2caw0zfrzihwhey4] [PlaybackSessionController] could not retry, reporting error
PS: DTS Works just fine even DTS-MA when DCA is enabled. So the only issue here is with TrueHD 7.1 which needs to be transcoded to EAC3 and it fails to do so with the new client version.
**[quote=“dantebarba, post:1, topic:759233, full:true”]
Logs:
“retries”: 1,
“id”: 1556,
“streamType”: 1,
“default”: true,
“codec”: “hevc”,
“index”: 0,
“bitrate”: 35194,
“bitDepth”: 10,
“codedWidth”: 3840,
“colorRange”: “tv”,
“height”: 1600,
“level”: 153,
“refFrames”: 1,
“width”: 3840,
“id”: 1557,
“streamType”: 2,
“selected”: true,
“default”: true,
“codec”: “truehd”,
“index”: 1,
“channels”: 8,
“bitrate”: 4420,
“bitDepth”: 24,
SOLVED
Context:
I’m running Plex behind a reverse proxy (Traefik + Docker). Plex is configured so it exposes the URL to plex.tv (https://myplexurl.com:443). This URL is then retrieved by the Samsung Plex client and is used for streaming.
I have to say this configuration has been working and I didn’t have any issues playing back whatever kind of movie I threw at it. True HD, Atmos, DTS-MA, 4K HDR everything worked flawlessly.
Looks like an update of the Client APP has introduced some kind of modification on how the transcoded chunks are retrieved from the server. This caused that Plex only worked if Direct Play was enabled, but if Direct Stream was needed then it didn’t work at all.
Solution
If you are running Plex under a reverse proxy you’ll have to expose port 32400 and make plex available publicly. Unfortunately is the only solution that I’ve found.
ok so my Tizen version is 1280 and there is a 1300 available. I have autoupdates off so it’s not Samsungs fault. Plex has broken the app itself. Please I do need to rollback
Any news?
Solved see edit.
