Unraid Docker Plexinc Version Version 4.22.2
I have been looking around and I found this website
https://thestreamingadvisor.com/how-to-listen-to-audiobooks-with-plex/) that talks about adding Audiobooks to plex,
but when I go and look for myself, I discovered that my version of plex don’t match this guide.
so my question is: is this function a PlexPass option only or am I missing something
This is not the version of the Plex server, but probably merely of the Plex Web app.
At which point of the guide are you struggeling? Which function are you missing?
I would like to add my audiobooks to my plex so that I can play them through my Phone app was I am now stuck at home.
cos at the moment when I try to play them from my phone, the chapters are out of order.
Did you follow that guide? If yes, where did you encounter problems?
I did a dry walkthrough to see what I need to do and I I got down to here https://thestreamingadvisor.com/wp-content/uploads/2018/02/Pic-7.jpg
and I saw that my plex was differant.
the only thing I an no sure about is the Metadata Scraper and will it work within a Unraid Plex Docker
Yes music library has witnessed changes in the past, so yes this looks different now. If this still works I don’t know, but you can try it out. The scaper should be also installable on unraid, as you have full access to the PMS config folder. I would start with this and see if it shows up in PMS. I am not sure if this still works as plugins (and scrapers) have also seen “changes” in the past. But it is worth a try.
I would work my way from there, maybe tagging only one single audio book just to try if things work.
ok no change I have followed the instructors and still no option for AudioBooks. I will add this as a request
There are several requests for audiobooks, just vote for the one with the highest number of votes.
