Auto change metadata
Hallo everyone!
When I for example change the name of the movie and save it. Couple hours later it’s back to its original name. Goes for the age restriction as well. Can anyone help!?
Ray
Go to the ‘preplay’ page of the movie
click on the ellipsis ( . . . ) up, right
pick ‘Match’
then ‘Auto-Match’
Then ‘Personal Media’
The above is for videos, which are not listed at the IMDb or TheMovieDatabase
If this is however a normal movie, it is better to ‘match’ it to an entry on those databases.
Either by using ‘Match/Fix Match’ or, even better, by naming your media file the recommended way right before you add it into Plex.
