i want to change how movie titles appear which appears to be easily done using the edit tool… is there anything that will change/undo these edits once done, like updates or server refreshes? in short, i want to protect all of my changes… i noted little yellow lock icons next to title names, does activating them protect them from being changed? if so, is this the only way to protect the changes?
intuitively it seems that entering the movie’s “original title” during the edit process would allow plex to add the movie’s correct metadata upon refresh, regardless of what’s entered for “title” and “sort title”, which is what happens with kodi (and extremely quickly i might add), but that’s not the case, i’m having to add poster art manually, adding the movie’s “original title” in plex doesn’t seem to effect anything… example: arrival (2016).
plex did a pretty good job adding the far majority of my movie files to the library but failed to add 10… assuming i can identify which 10 they are, how do i go about manually adding them?
thanks very much.
