Hey plex community :),
I wanted to use WOL to start my Plex server automatic if there is a incoming client connection and suspend the server, when no client is active. So where’s the problem?
I can start my server automatic, if there is a client connecting. (I use a Fritzbox router, which has the option to automatic wake network devices per magic packet, as soon as there is a incoming activity for that device.)
My server is running xUbuntu 18, but unfortunately, there is no way to control the auto suspend function if there is a client watching. So the server goes into suspend, even if someone is watching.
Therefore I made a simple bash script for using with Ubuntu: It’s called PlexChecker, and checks several conditions, before putting the server into standby:
It is NOT perfect or beautiful, I know that, but I wanted to share it, because I found nothing else which does the trick. You are also free to mod it
Things that are checked before going into standby:
- CPU usage,RAM usage and Running time of the Plex Media Server process
- Active Plex Transcoder processes
- Active network connections of Plex processes
(Transcoding and direct plays are covered)
It’s working fine so far, you have to run this as root, I run it hourly under the root cron
Steps you have to do:
- Disable the builtin auto suspend function of xUbuntu / Ubuntu
- enable WOL
- Put the content into a PlexChecker.sh file and run it under root cron hourly
Here is the code:
#!/bin/bash
#Script for looking after active Plex sessions
#If nothing is streamed, Server goes into suspend, wol works automatic with a fritzbox
#This checks for:
#1. CPU usage,RAM usage and Running time of the Plex Media Server process
#2. Plex Transcoder processes
#3. Active network connections of Plex processes
#17.09.2019, muhagl, V1.0, tested under xUbuntu 18, run as root!
echo '[PlexChecker] Check for active Plex connections...'
logger '[PlexChecker] Check for active Plex connections...'
TranscoderActive=true
CpuUsage=0
RamUsage=0
RunningTime=1
NetworkConnections=100
echo '[PlexChecker] Checking...'
logger '[PlexChecker] Checking...'
### Check for active Plex Transcoder process:
pgrep -x "Plex Transcoder" >/dev/null && TranscoderActive=true || TranscoderActive=false
### Check if Plex Media Server process is running as active (time diff 3 Mins) 0=Idle, everything else=active:
timeval1=$(ps aux | grep "/usr/lib/plexmediaserver/Plex Media Server" | grep -v grep | awk {'print $10'})
sleep 180
timeval2=$(ps aux | grep "/usr/lib/plexmediaserver/Plex Media Server" | grep -v grep | awk {'print $10'})
#Remove :-sign from string
timeval1=${timeval1/:}
timeval2=${timeval2/:}
RunningTime=$((timeval2-timeval1))
### Check for network connections:
NetworkConnections=$(netstat -p | egrep -c *Plex)
### Check CPU & RAM Usage of Plex Media Server process:
for i in {1..60}
do
#Get CPU Usage
cpuval1=$(ps aux | grep "/usr/lib/plexmediaserver/Plex Media Server" | grep -v grep | awk {'print $3'})
#Round value
cpuval2=$(echo "($cpuval1+0.5)/1" | bc)
#Get RAM Usage
ramval1=$(ps aux | grep "/usr/lib/plexmediaserver/Plex Media Server" | grep -v grep | awk {'print $4'})
#Round value
ramval2=$(echo "($ramval1+0.5)/1" | bc)
#Save them
CpuUsage=$((CpuUsage+cpuval2))
RamUsage=$((RamUsage+ramval2))
sleep 3
done
CpuUsage=$((CpuUsage/60))
RamUsage=$((RamUsage/60))
### If ElseIf clauses:
if [ "$TranscoderActive" = true ] && [ "$CpuUsage" -ge 1 ] && [ "$RamUsage" -ge 4 ] && [ "$RunningTime" -ne 0 ] && [ "$NetworkConnections" -gt 15 ]; then
echo '[PlexChecker][1] Streaming is active, I do nothing...'
logger '[PlexChecker][1] Streaming is active, I do nothing...'
elif [ "$TranscoderActive" = false ] && [ "$CpuUsage" -ge 1 ] && [ "$RamUsage" -ge 4 ] && [ "$RunningTime" -ne 0 ] && [ "$NetworkConnections" -gt 15 ]; then
echo '[PlexChecker][2] Streaming is active, I do nothing...'
logger '[PlexChecker][2] Streaming is active, I do nothing...'
elif [ "$TranscoderActive" = false ] && [ "$CpuUsage" -eq 1 ] && [ "$RamUsage" -le 5 ] && [ "$RunningTime" -eq 0 ] && [ "$NetworkConnections" -le 10 ]; then
echo '[PlexChecker] Suspend because nothing is active...'
logger '[PlexChecker] Suspend because nothing is active...'
echo '[PlexChecker] It is time to suspend :)'
logger '[PlexChecker] It is time to suspend :)'
systemctl suspend
else
echo '[PlexChecker] Something is active but is not catched under the If Else clauses, do nothing...'
logger '[PlexChecker] Something is active but is not catched under the If Else clauses, do nothing...'
fi
Greets
