My Problem: I configured plex on my raspberry pi 2 in combination with plexconnect and my ATV3. Unfortunately a huge set of our movies is in avi format, so the RPI2 cpu load during broadcasting is very high due to live-transcoding (from avi to m4v). As a result the movies are interrupted every couple of minutes for a couple of minutes …
Idea and assumptions:
- I would like to convert my avi files to m4v in advance to avoid the necessity of live-transcoding.
- Assuming that RPI2 is running constantly anyway it will have enough time to perform the conversion until time comes when I will want to watch the movie.
- I don’t want to start each conversion process manually because there is a running system …
With other words:
I know there are a couple of software version out there that allow conversion of single movie files to another format. But what I would like to do is to establish a procedure that is kicked once I add a new movie to my plex media server (similar to grabbing movie information from the databases) and which converts the movie into another defined format (m4v).
Question:
1. Is there a possibility to use the transcoding tools for movie-conversion ans storing into a new file in advance?
2. Alternatively: Is there a software for format conversion that can be started via shell script?
Version #2 might allow a background process that checks constantly for new files in my movie folder and that starts conversion for new files once they are detected.
