Automatic Subtitle Selection
Hi!
The automatic subtitle selection is disabled once you change the subtitle manually. Can we have an option please to not disable it and when you change the audio language then it always changes the subtitle for it as per the language settings.
When you change it accidently then the feature is disabled permanently.
Thank you
A post was merged into an existing topic: Forget Audio and Subtitle Selection after XXX days or Watched
A vote has been moved.
2026 clean-up: duplicate
