Automatically hide player controls
Hi!
After pausing a video and starting it again, is there some config to hide the player controls automatically?
As it is today, it seems that I always need to press “ESC” on the remote control to do that…
Thanks.
Regards.
[This second post is duplicated, not the first one. The question is still valid. Sorry. Thanks.]
what do you mean?
by default it hides the GUI a few seconds after you resume the video
Hi!
Thanks for reply and sorry for the delay.
No. The GUI keeps on the screen forever. In RasPlex, at least, I really need to press “ESC” on the remote control to get rid of the player controls…
Regards.
it does glitch some times but mine hides the GUI 99% of the time automatically without a problem.
Ok.
Do you remember (or can check) how many seconds do you wait until the controls disappeared?
Thanks.
