Any1 knows A385 Avermedia Volar HD is compatible with plex for live TV with plex?
Thnx
Thnx
The supported devices are listed on the blog post.
Can some1 explain how is a normal USB tuner works with plex? I mean if u got supported usb tuner, just simply plug to the computer installed plex server and can tune the free DVB-C programme and can stream them?
Thnx
Yeah, exactly, providing that the USB tuner is one of the ones supported, and is supported on the OS that plex have listed it will just work.
thnx, already bought a compatible tuner stick, just I dont find how can I stream local tv shows (not in US). I see only can be recorded a show but how can I see on air show (local program)
Any help some1?
