Background DVR convert from .ts to H264 or H265
Server Version#: 1.42.2.10156
Player Version#: web
I have a large library of TV Shows collected via DVR which stores the recordings as .ts files. These are MPEG2 files and it seems I could save storage space on my NAS if there was a way to automatically convert .ts files to H265 (or H265) files in the background.
I found a set of scripts on github here:
Seems like it would be better to have this feature built into Plex. Any ideas? Worth a feature request?
This converts mpeg2 to h264 (still in a .ts file)
If you would like a simple and free solution to change file containers, MKVToolnix is a fantastic solution and some. Adding Subtitles, removing unwanted subs, Adding Track Flags, naming, Joining split movies and more. A must have when collecting a Library.
Thank you! Very helpful.
