Backing up all data including media data
Server Version#: 4.147.1
Hello,
I have Plex running on Peppermint Linux.
I have a lot of manually edited media data and hate the idea of having to re-edit everything, for hours.
My question is how can I save this data as a back-up?
The reason is I need to reinstall the OS, which will mean a new installation of Plex.
So hopefully someone will have a answer on how to save everything.
https://support.plex.tv/articles/201539237-backing-up-plex-media-server-data/
https://forums.plex.tv/tags/c/plex-media-server/computers/server-linux-tips
Thanks for your reply and link, I have not been able to get that method to work.
I have also tried to access though a live disk but, preferences.xml will not copy over.
To be truful I’m at a bit of a loss, any surgestion welcome.
@Joker7
Is PMS fully stopped as you create the .tar.gz ?
Also, if space is not a concern, you can remove the z (compress) option.
It will finish much quicker. It will be dependent on disk / network speed only.
It would become:
sudo bash
tar cf /path/to/somewhere/PlexBackup.tar ./Library
Thanks you for your up-dated reply.
Plex server stopped by:
sudo service plexmediaserver stop
I can’t get any of the commands in the link to work, it maybe it’s something to do with Peppermint/Debian and not real understanding Linux is not helping.
I have a copy/back-up apart from preferences.xml, which I obtain by running a live disk. I know plexmediaserver has stopped as the OS has not booted.
Zipping/Tar is not really a problem has I have plenty of space to save it to.
