Save plex media serveur
Server Version#: Version 1.20.0.1406-f47a81b7
Player Version#: Apple TV
Hello,
First of all I would like to apologize for my English which is not perfect …
I would like to know, in the case of a debian formatting, what should I backup to get Plex back exactly as it was.
I suspect that I have to backup my data (video and photo files) it’s obvious but I’d like to find the same configuration exactly as it was.
Is it enough to backup and put the following file back in place?
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Preferences.xml
Or should I back up the entire folder: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/
Thank you for your help!
Basically you’ll need the full Plex data directory (/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/).
You can use the support article on how to move to a new setup (knowing it’s not a 100% match… but it’ll cover all important steps).
https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
There’s also a post in the tips & tricks section addressing how to backup/restore your PMS:
Super thanks a lot for your answer.
I will now proceed to save the complete file:
Then I would put this folder back on the new installation.
Thank you for your answer.
