Metadata Backup
Hey everyone, I tried this before, but I don’t think I knew how to ask the question. First off, I DO NOT have Plex-Pass. I have already made a backup of the server as a whole, now, I’m trying to backup the metadata of plex itself. I have over 1500 movies and of the 1500, about 300 did not populate with movie posters, descriptions, year released, etc. I have MANUALLY put all that information in. I would like to backup the entirety of the 1500 movie library metadata so that if need be, I can use the backup and not have to spend days re-entering information. Any advice?
If you need ANY information, let me know!
Thanks in advance! I don’t know what I would do without this community.
-Mike
Well, no soup for you! :rofl:
Doesn’t matter. And if you had one, it would show next to your username on the forums.
If possible, stop Plex Media Server before performing the backup. That ensures the database files are closed and properly backed up.
Backing Up Plex Media Server Data
Use the Plex Movie scanner/agent; follow naming standards; add IMDB/TMDB ID to the folder & file name.
Naming and organizing your Movie files
Also, for artwork, consider placing the files in the same folder as the movies, instead of adding them to the database. They will be easier to change. Also, if you ever point another Plex server at the same data, the desired poster is already in place.
Local Media Assets – Movies
Sorry, I just got around to seeing this. I don’t quite understand, there’s not like a metadata config that I can just copy and paste? I’m moving from one computer to an actual server, so I’m just moving everything. That’s why I’m asking. I did all the editing and such in plex. Like, movie pictures, synopsis, years, etc. Thanks.
The info about file naming, etc was to help with matching when adding media to your server. It is not about moving to a new system.
Regarding moving to a new system, metadata is stored in the Plex Data Folder. Make a backup of the folder, then copy it to the new system.
See the support document below for additional details.
The procedure will clone your old server to the new server - same name, etc. You cannot run both simultaneously.
Disabling “empty trash automatically” is important if the path to the media is different on the new server. You do not want Plex Media Server on the new system to start, not find media in the expected location, and remove associated movie names, artwork, etc.
If you want to run both servers at the same time (which is not a problem), do not copy the Preferences.xml file to the new server. Let Plex create a new Preferences.xml on the new server.
Keep the backup of the Plex Data Folder during the move process. That way, if something goes wrong, you still have the backup to help with recovery.
https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
Hey @FordGuy61 . I appreciate the help. I couldn’t find the plexdata folder at all. I googled and googled and after starting over, I found the “match” button and matched to appropriate titles.
However, out off all my movies, only 2(which is great!) were not available to match. So, with match, is there a way that I can add actors, times, dates, etc and help update the system or point to it?
Also, regarding this folder now that I spent all that time matching. Any idea how to back up the newly acquired match and data? Thanks!
For future reference, in the forums, text in orange is a link. Click on Plex Data Folder. The document lists the location of the folder for multiple OS, including FreeBSD.
Here’s the process for Linux: Back up/ Restore /clone your PMS metadata
The process for FreeBSD should be similar (I run Plex on Ubuntu, not familiar with FreeBSD specifics).
Also: Backing Up Plex Media Server Data
If I may add?
I’m using free BSD, so I ssh into the server, goo to the path. The path isn’t showing for me. Nothing in any directory says plex data so far.
Just saw this, will check it out and get back to you. Working hard today! hah
@epke_michael_yahoo_com
From the support page:
https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/
FreeBSD
/usr/local/plexdata/Plex Media Server/
I tried that, not there. However, I haven’t followed the guide you posted on creating it yet? I think I expected it to populate when plex was installed, etc? Let me know your thoughts.
I don’t have a BSD VM here.
If you can find the file com.plexapp.plugins.library.db , you’ll find where it’s at
(BSD has the find command ? – find / -name com.plexapp.plugins.library.db -print )
You’ll want Plex Media Server and all its contents
