I’ve read all the posts on the forum touching on this but I cannot find a way to add BBC Documentaries to plex where it will pick up the metadata from thevdb.com? I’v
To be clear I am talking about one off BBC documentaries as covered here. Other BBC series pick up fine but I have about 100 one offs!
thetvdb.com/?tab=series&id=79660&lid=7
For example I had it setup in Kodi and it worked perfectly with the following structure (and all other shows on Plex are working with this format):
TV Shows/BBC Documentaries/Season 2016/S2016E278 - Britain’s Star Men.mp4
It will show up in plex but not with any metadata or posters. I have tried with or without season folders, with and without spacing between the season and episode in the filename, with and without the title in the file.
I think there is some confusion coming in as the files themselves have metadata stored in them which its picking up. Is there a way to configure the agents not to use local info? I only stumbled on this as I was following another thread on here forums.plex.tv/discussion/comment/1205792#Comment_1205792 where they showed an example of it working with a set naming convention and out of frustration I tried it myself renaming the above file as this other show that was picked up but plex still identified it as Britain’s Star Men.
