TLDR; A bunch of newbie questions…
I’ve had PMS and PMP running on my Windows 10 Pro box for a while for a test drive and having some good results. Enough success that I’m now beginning to research possibilities of running PMS on a NAS and after reading dozens of articles and posts on how to choose a NAS for Plex, I’ve gotten a bit confused. Perhaps someone could give me some advice to help me get things straight (or even point me to things to read that I may have missed)…
My first couple questions are about the Plex NAS Compatibility chart.
[1] I very much appreciate the time that was put into the chart, but I was wondering if it’s exhaustive. For example, as I’ve been researching, I’m finding NAS models that claim to be “Plex compatible” but aren’t on the chart. I know there are potential issues with PMS being able to access the hardware-level transcoding on some NAS models, there may be insufficient CPU power to do software transcoding, etc. and I’m inclined to trust the compatibility chart more than a manufacturer’s marketing materials. But I was wondering if there’s anyway to classify a NAS that isn’t on the chart (in case it just hasn’t been verified and posted yet).
[2] The second question is about the transcoding characteristics. It seems to me that if a NAS in the compatibility chart lists it supports a particular type of hardware transcoding, then it really doesn’t matter whether or not if it supports the same kind of software transcoding, since hardware transcoding would always be preferred. Is that correct, or am I missing a key point?
[3] It looks like (as of this post) most/all of the options for the 4k transcodes are “Decode Only”. I think I read that transcoding is required when showing subtitles if they’re not burned in to the source. So would that mean that there’s no way to get subtitles optionally on/off for 4k content since there’s no way to transcode it (and not transcoding 4k is one of the rules of Plex)? Maybe I totally misunderstand the subtitle/transcoding thing… [I don’t have any 4k content yet, but I’m trying to plan ahead a bit, and also want to set things up to direct-play with pre-transcoded stuff as much as possible, anyway, but I do use subtitles a lot]
[4] Looking through the Plex forums, there seem to be a wealth of positive and negative experiences with PMS on the different manufacturers’ NAS devices. Is there any particular brand that you all would consider more reliable than others? More capable? Less issues when PMS is updated? I want to use the NAS not only to run PMS but also for other stuff (I plan to look into how I’m going to partition things into volumes later, but plan to use at least Raid5 for everything).
[5] Some of the NAS models come with beefier power supply options. (For example, QNAP TVS-882). When would it make sense to consider a more robust power supply?
[6] I was trying to estimate space/bandwidth for capacity and connectivity. I was using 25Mbps as a guide for a single stream of 4k HDR. Would that be a good estimate? I was not able to find consistent estimates for space for 4k video at h.265. Does anyone have any first-hand experience for that (I realize that it can vary quite a bit depending on how it’s transcoded, like with Handbrake, for example).
[7] A bit off-topic, but thought I’d ask anyway – I’m also thinking about a box to use for streaming services, but would also want it to run the PMP client. Thinking about Shield or Roku. Anyone have opinions?
Sorry for such a huge wall of newbie questions, but I’ve read so may posts on so many topics with help from the Plex community, I thought I’d ask about this stuff so I can understand better before spending several thousand dollars on something that I might later regret.
Thanks in advance for sharing your experience, knowledge, and helping me to learn. Very much appreciated.
