Best 1080p streaming device for Plex
Unless the Roku behaves differently from every other Wi-Fi device, I don’t think there’s anything sinister or mysterious going on.
The Roku has one Wi-Fi radio. When it associates with the Internet Wi-Fi, the radio gets tuned to that channel.
When the Roku creates a Wi-Fi Direct SSID, it uses the same channel, because the only radio is already on that channel. It doesn’t assume the Internet AP knows anything and it doesn’t “chase” that SSID. I just IS on the same channel.
Wi-Fi uses CSMA/CA to sense other activity and avoid interfering with it. The Roku, like other Wi-Fi devices, literally listens before transmitting. It will delay transmitting if it hears somebody else talking. That’s how the spectrum is shared. It’s also how Wi-Fi can share the spectrum with non-Wi-Fi devices. (It’s ALSO why non-Wi-Fi devices that don’t use CSMA/CA can hurt Wi-Fi devices so badly - they don’t take turns.)
This is true when there’s one AP and multiple clients on a network; everybody listens before transmitting. CSMA/CA also works pretty well if there are two different APs on the same channel. The APs aren’t in charge of who can talk, anyway. So it doesn’t really matter if there’s one AP or two or 5. Everybody listens before transmitting.
That screenshot describes ACI - Adjacent Channel Interference. ACI is kinda harder to deal with, and happens in partially overlapping systems. It somewhat defeats CSMA/CA, because devices can’t “hear” each other consistently. You end up broadcasting garbage or getting talked over and getting errors.
I have no idea what the Roku is doing to avoid ACI. None of those look SUPPRESS THE ACCESS POINT or SCREAM LOUD or BREAK WI-FI, and that would be pretty foolish of the Roku. I also haven’t found any explanation of what those settings do, and I’m very curious! One strategy in noisy Wi-Fi environments is to use tiny packets, so that if others are talking on top of you, your packets take less time to make it through. That doesn’t negatively impact others. Another strategy is to break the Wi-Fi protocol and not wait your turn before sending - that does hurt others, but only when you are transmitting data. If anybody breaks Wi-Fi like that they deserve to be shamed.
Two APs on the same channel have little negative impact on each other if the channel isn’t saturated. Everybody takes turns, and it’s almost the same as if they were all joined to the same AP.
There are some bad ideas about how to do Wi-Fi spectrum management out there. There are even some APs that have dumb ideas about how to choose channels, and that “run away” (change channels) if they see another AP in the same frequency. Or if the other AP in the same channel is “loud” - whether it is active or not. Being able to hear another AP clearly is GOOD, because it’s easier to avoid talking on top of each other.
Obviously the ideal situation is to have no overlap at all. But the existence of another AP isn’t a good reason not to choose a channel. What matters is spectrum utilization. Access Points that change channels because they hear other APs are a special kind of stupid.
I see a few comments from people saying that the Roku Wi-Fi Direct interferes with their system, and that turning it off helps. I can’t argue with that. They also frequently say “I can see the SSID”, which is to be expected, and “My system changes channels automatically”, which is an indicator that they’re changing channels for the wrong reasons. “The FCC should be involved” is just a huge red flag. So is “I have lots of repeaters so I should have strong signal”.
My surprise is that the amount of traffic for a remote control should be very very low, and even more so if it’s just advertised but idle. If the existence of another (idle) AP causes another Wi-Fi network to totally collapse, something is already very wrong. I mean … definitely address the symptom, but maybe investigate the underlying problem, too?
I’m not claiming that two networks won’t contend for airtime. They absolutely will. But they should do it in a very predictable way, and it should be very similar to just having all of the devices on the same network in the first place.
And I’m not claiming that people haven’t had problems. I’m saying this pushes my “technology voodoo” buttons. I’d love to know what was really happening to those folks. I’d love to know what those settings actually do. There are tons of badly behaved Wi-Fi devices. Maybe the Roku is one, or maybe affected people had other badly-behaved Wi-Fi devices.
I haven’t been able to find an explanation of the Roku ACI settings or an explanation of what the Roku was doing wrong and why these networks were being so significantly impacted.
I love this stuff. Understanding how things go wrong is really interesting to me.
Looks like a timely update for the webOS app (though still in preview):
I have a Roku 4 right now and the battery on the remote totally blows! How long do the batteries in newer Roku devices last?
I forgot to consider about the LAN connection. I’m aiming for everything to direct play so as much as possible a Gigabit connection is preferred over 802.11AC wifi. So the Fire Stick has a separate adapter for this?
How bad is the Fire Stick Plex app?
sure… forget about that Gigabit.
I can touch both the stick and the router - I’m 6’4" tall.
5G is working fine. <— my bit rates are under 20M - mostly under 12M.
The audio when playing mp3s - is so low I can’t use it. My only audio complaint.
the unit is snappy and works well. I have no complaints about it’s performance, in general.
It’s like being kicked in the face by a dozen bikers. <—the new player isn’t bad.
In order to love the Android App Family you have to be such a fan of the devices that when you walk into a room with one of them - your panties fly off.
In short - if you’ve used the Roku Uno App - anything else is a compromise.
Note: ‘some’ improvements have been made and are, IMO, moving in the right direction - at a Glacial Pace - one that’s still frozen. If they want a better review than that - promises don’t feed the bulldog.
2 weeks on this set… the report is: 90%
last year it would have been 90%, 'cause I would have put a new set in 3 days ago.
Ok. The fire stick 4k is now on sale at $34.99 so I guess I’ll bite the bullet. So in general, you can recommend the fire stick too, right?
The 4K Fire Stick is fine.
The Plex you have to run on it is awful - simply awful.
It will fail at something you need.
Guaranteed.
I bought one for the Fire Stick things it can do - and because you can’t hate something properly if it isn’t in your face - and if a miracle happens I want to be there to witness it.
That’s about what I paid for ‘the refurb’ I got - so it’s certainly cheap enough.
You can get this Roku Ultra BRAND NEW for $69:
I recommend that 'cause the Plex App on it is great.
The Fire Stick is an experiment - and to use for Amazon stuff.
Here’s a hot tip tho… if you do get the stick get one of these too:
You can bring the stick (any stick) out into some ‘clear air’ that can see the WiFi better and be cooler. I velcro-strapped mine in with cables - it’s invisible, but functions great.
Ok, got it. I will be running Plex so I guess Fire Stick 4K is a no-no (cancelling my order now). As for the Roku Ultra, is that their latest device currently? Any caveats to it compared to the Shield TV?
The Roku Ultra won’t do Super Duper Audio.
Neither will the Fire Stick - so between those two the Ultra is the best bet.
The Shield has no such limitations as far as I know - but it’s $200. <—and runs the same crap app as the Fire TV. <—you’ll have to make that call.
What kind of crappiness for the Plex app in both fire tv 4k and nvidia shield tv are there? I have an nvidia shield tv pro for my 4k tv and it looks to be working fine.
Well, if you’ve never seen the Roku UNO App - you have nothing to compare it to.
It’ll be the same thing you’re used to.
Android is Android.
Is the Roku UNO app the same OS in the Roku 4? I still have a Roku 4 anyway (and it supports 4K) so won’t that do a decent job for Plex on a 1080p TV rather than investing on more recent hardware?
The Roku 4 was dead before they ever released it.
If you have one - hook it up - install the app and give it a go.
There’s only one (well, two) Plex Apps - The Public and The Preview:
The Public is in the Channel Store.
The Preview is a private channel:
You’ll find out really quickly what’s gonna happen - and I don’t know what’ll happen. Never owned one. I went from a Roku 3 to an Ultra.
If you have a Plex app on the Roku 4 already - it’ll update to the newest Public as soon as you hook it up. If it doesn’t - invoke an update manually - System/Update
Ok, got it. Let me give that a spin. Why do you say it was dead before it was even released? Is it that sucky?
I remember using it with Plex in the past and had no problems with it but that time was when I was starting out with Plex and my media were very low quality. Now that I pretty much have very high quality media, I don’t know how it’ll cope up but I’m expecting that it’ll do just fine for simple TV series streaming.
I have my Nvidia Shield TV Pro for the very large media movie files anyway.
You’ll have to try it, Man.
Us old timers lived through the Roku 4 on Roku Forums.
I didn’t have to buy one to find out.
Some people liked it.
Tell us what you think.
