Best Plexamp settings
I live in a mountainous area, so cellular isn’t so nice to me. Neither is WiFi. What’re the best settings, if there are any, for remote access to work? I’m tired of the endless loading when I go for drives.
Server Version#: 1.19.4.2935
Player Version#: 3.1.1
It sounds as if you may want to increase the caching. Settings -> Advanced -> Caching. From there, you can increase the number of upcoming tracks stored, and the overall cache size, so you can maximise what’s grabbed by your device when it does have signal
What’s a good number to start with?
Well, I’d probably bump it up 2-4 steps for cache tracking, and the cache size subtitles should give a suggestion as to what might be best in your situation. Maybe 2GB or 4GB?
How does that look?
I’d probably bump up the WiFi caching, as it’ll then cache more tracks when you’re on WiFi, so when you lose WiFi coverage, you’ll have more cached. Best thing to do is try it out and see how it performs :slight_smile:
I see. I bumped it to 40 songs. We’ll see how it fares. Thanks for the help.
No worries! Let us know how you get on!
