Best practise backup
Server Version#: 1.26.2.5797
this morning I downloaded and installed 1.27.0.5849 and when the server started up I got an error occurred message. I rolled back to 1.26.2.5797. In the process, something went wrong and my library showed the latest added content in a completely wrong order. I got it all fixed but I would like to know how I can best backup my setup so when something goes wrong and I need to re-install or start over, I can link to my library and still keep the latest added order. Is there a way to do this and if so how?
My videos shows. 2017 one then a 2019, etc instead of the order I added then. same with another library. I fixed it by adding them back to a different folder in chunks but now is the time to back all this up to restore it if ever needed and try to do this daily or at least weekly.
thanks for the help
Hi cmeisel,
Super4Jet
Thanks. I backed up the data directory but I don’t have the “com.plexapp.plexmediaserver.plist” file under ~/Library/Preferences/
It is not there. Did this location change with 12.3.1, Montery?
