I know Editions is not supported for Shows and there is no ETA.
The issue I’m running into is that one of the editions gets ignored entirely. Right now I’m battling with Gundam SEED and Gundam SEED Destiny broadcast and HD remasters. Only one edition of either show is visible in the Plex Player unless I’m in folder view.
I’ve tried various combinations of no tags, tags on only the original broadcast, tags on only the HD remasters, and using tags from TMDB on the originals and TVDB on the remasters. I think part of the issue is that…
On TVDB:
Gundam SEED: 254931 (Aired Order)
Gundam SEED HD: 254931 (DVD Order)
Gundam SEED Destiny : 74890 (Aired Order)
Gundam SEED Destiny HD: 74890 (DVD Order)
On TMDB:
Gundam SEED: 20111 (as Original Air Date Season 1)
Gundam SEED HD: 20111 (as HD Remaster (TV) Season 1)
Gundam SEED Destiny : 20111 (as Original Air Date Season 2)
Gundam SEED Destiny HD: 20111 (as HD Remaster (TV) Season 2)
Based on that, I think I would need to ignore the auto tagging? But I can’t figure out how to get everything to show up, then disable remote assets for only these shows. I have Local Media Assets (TV) enabled and dragged above the the other other asset sources.
Has anyone come up with a workaround?
Server Version#: 1.29.2.6364
