[Beta] Signal Path Light?
Continuing the discussion from Plexamp Release Notes:
I’m looking and not seeing where this new feature is located - any tips?
also on the topic of codecs, I’m finding on '33 that the ‘Sonically similar albums’ section on Album pages have the codec info clipped and there’s a little scrollbar active on the right, so some sort of padding quirk
The light only shows while you’re playing to a Caldera player on its latest beta, since that’s what publishes the signal path; playing on the computer itself there’s nothing to show. The clipped codec line and scrollbar under Sonically Similar Albums is fixed for the next beta, thanks for the screenshot.
