Better Bitrate / Transcode Options for Servers
I wanted to open up my server to more quality choices / 4K possibilities now that I have a better connection. And after some reading, I understand that when dealing with 4K, it’s best to take advantage of Hardware Acceleration, and to bump up my Remote Stream Bitrate to something 4k-friendly. No problem. But I’m finding that it’s being so wasteful with the bandwidth now, in non-4K situations.
I’ll attach an example. That episode is a 1080p file, in AV1 (which not many clients support yet, OK understandable). But it’s maybe a 2-3mbps rip. Since I have now toggled hardware acceleration to allow 20mbps 4K, its passing this job to the GPU (its a 6600XT) to transcode this 2mbps file to like, 17+mbps. That seems unnecessary. I was quite happy with making my CPU do the work, because I had only a 1080p collection and it could handle it easily, but it now seems that if I want to get into 4K, there aren’t many options to configure this the way I like.
So the feature request is:
  • Give the server operator more choices and control when it comes to transcoding, like - transcode 1080p and under using CPU only, to a max of X mbps. Transcode 4K content via GPU, to a max of X mbps. Something like that.
Thank you.
There’s already two existing suggestions discussing such an option. Please comment/vote in those threads to help us avoid distracting or cannibalizing votes.
Unless I’m missing some unique aspect of your suggestion I’ll close this thread as a duplicate.
That is expected when transcoding from av1 to h264. Av1 is similar in quality to 265. There is a 4x conversion factor used to maintain the quality for these codecs. Have you tried the new h265 transcode option? Also note that the number you see is the bandwidth of the connection to the server, it’s not the bitrate of the file.
Thank you for posting the 2 other threads. I did search (I swear!) but there are a lot of posts /complaints in this forum about transcoding overall. It was hard for me to find ones that were similar to this situation. I have upvoted them. And @MovieFan yes I do see the new x265 function, but got worried about the part that mentions its Experimental. So I have not tried it. Thanks guys.
