Is it possible to make it possible to allow more options for managing recordings and media libraries by making it possible to delete entire series or all series of a show or select multiple items and delete them to speed up removing old content in bulk.
Would you mind elaborating what you have in mind?
I’m not sure I can follow what you want Plex to add / what use case you’re aiming for…
If I record several episodes of a show… for example I record 30/40 episodes of a show over 6 seasons it would be good to be able to delete an entire season or all the episodes of that show at the same time from the app instead of having to delete each episode/recording individually!!
Thanks I thought I’d got that enabled it was snowing ticked and after checking turning it off and on and resaving settings it seems to work now
