- better buffer handling on videos with higher bitstream than 30mbits.
- audio passthrough (works on nvidia - doesn’t work on Sony TVs).
Problem is not on the Plex side, but on Sony.
Their firmware is total crap, it does not support frame rate switching, passthrough related API, …
@FuN_KeY said:
Problem is not on the Plex side, but on Sony.Their firmware is total crap, it does not support frame rate switching, passthrough related API, …
yes. there are things that are Sony dependent (or even Mediatek dependent) I don’t know.
But there are things to improve:
- Buffer (its kinda bad). There are players who just play files on the same firmware without lagging.
- AC3 passthrough? (kodi and netflix do it), DTS can be left as it is for now. As long as I understand it is not implemented in Sony’s firmware (read somewhere on the forums)
