Bind Plex to a special network interface
Server Version#: 1.18.3.2156
I have entered my interface (bond0.120) under Settings / Network / Preferred network adapter. The Plexmediaserver nei started and see that he has not bound the interface. I keep having problems with it.
Enclosed my Preferences.xml
cat /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Preferences.xml
<?xml version="1.0" encoding="utf-8"?>
<Preferences allowedNetworks="192.168.0.0/255.255.0.0" MachineIdentifier="99258f29-1ff8-4c05-9f86-9e28d27bb755" ProcessedMachineIdentifier="fc1ae6ac3f40c86dfa03375bb6f966450ce18632" AcceptedEULA="1" FriendlyName="plex.intern.example.com" PlexOnlineMail="sharbich@t-online.de" PlexOnlineToken="XXXYYYZZZ" PlexOnlineUsername="xyz" PublishServerOnPlexOnlineKey="1" DlnaClientPreferences="IP=192.168.120.20,DirectPlay=true,DirectStream=true,LocalResolution=1920x1080,RemoteResolution=1280x720,OnlineResolution=1280x720,LocalVideoQuality=74,RemoteVideoQuality=49,OnlineVideoQuality=49,SubtitleSize=100,AudioBoost=100,MusicBitrate=320" DlnaDefaultProtocolInfo="" CinemaTrailersType="0" FSEventLibraryUpdatesEnabled="1" DlnaAnnouncementLeaseTime="1800" GdmEnabled="0" LastAutomaticMappedPort="10114" DlnaDescriptionIcons="" DlnaEnabled="1" ManualPortMappingMode="1" ManualPortMappingPort="32400" allowMediaDeletion="1" autoScanMusicSections="1" AnonymousMachineIdentifier="6f3f90a6-fe87-497c-a3ba-2304a4bcb3ee" GracenoteUser="WEcxA2bfKXOe8+JNj3FWh5LiWp1YxfIzvpKNXobK0mDJkh4PuHRxfOwVAQX2q+GPK60+t4SJXFqQzSY280n8Iy6nrkXExGBml7Rp4Z4/EwdWtstAqeHmY23P1M7haVWuQKx7TX7MT4pOIRkWgeqgXLRVnljem7Um8zQAvp74lBABbrVIJiOrfPsBXNua4HlzYLT/aA==" CertificateVersion="2" PlexOnlineHome="1" ScheduledLibraryUpdateInterval="86400" ScheduledLibraryUpdatesEnabled="1" MetricsEpoch="1" agentAutoEnabled.com.plexapp.agents.lastfm.Albums.com.plexapp.agents.lyricfind="1" agentAutoEnabled.com.plexapp.agents.plexmusic.Albums.com.plexapp.agents.lyricfind="1" LanguageInCloud="1" CloudSyncNeedsUpdate="0" FSEventLibraryPartialScanEnabled="1" watchMusicSections="1" PubSubServerPing="77" PubSubServer="139.162.158.105" OldestPreviousVersion="legacy" DlnaDeviceDiscoveryInterval="5" PubSubServerRegion="fra" secureConnections="1" customCertificateKey="" customCertificatePath="" ServerBindInterface="bond0.120" CertificateUUID="3e8aaa2e0ae4451ab72ab73f79ef46e5" PreferredNetworkInterface="bond0.120" DvrIncrementalEpgLoader="0" EnableIPv6="0" LanNetworksBandwidth="192.168.0.0/255.255.0.0"/>
The plexi media server listens to every interface. I just do not understand?
netstat -tulpn | egrep "Plex"
tcp        0      0 127.0.0.1:37829         0.0.0.0:*               LISTEN      23771/Plex Plug-in
tcp        0      0 0.0.0.0:32400           0.0.0.0:*               LISTEN      23661/Plex Media Se
tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      23661/Plex Media Se
tcp        0      0 0.0.0.0:32469           0.0.0.0:*               LISTEN      23736/Plex DLNA Ser
tcp        0      0 0.0.0.0:1208            0.0.0.0:*               LISTEN      23736/Plex DLNA Ser
tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      23727/Plex Tuner Se
tcp        0      0 127.0.0.1:43705         0.0.0.0:*               LISTEN      23813/Plex Plug-in
tcp        0      0 127.0.0.1:35263         0.0.0.0:*               LISTEN      23676/Plex Plug-in
udp        0      0 192.168.150.20:59661    0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:6437            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:14755           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.190.2:47577     0.0.0.0:*                           23661/Plex Media Se
udp        0      0 192.168.120.20:43555    0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:2824            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:15168           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.110.20:35834    0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:7530            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.20.30:36312     0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:3641            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:11931           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.20.25:40943     0.0.0.0:*                           23661/Plex Media Se
udp        0      0 192.168.130.20:49260    0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:13072           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.20.28:41831     0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:50092           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:5047            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:13308           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.20.20:37942     0.0.0.0:*                           23661/Plex Media Se
udp        0      0 192.168.140.20:58622    0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:10056           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:1901            0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:42914           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.20.26:38869     0.0.0.0:*                           23661/Plex Media Se
Since I had the PlexPas extra because the interface could be bound and now the whole thing does not work. Sometimes it worked, then again after an update no longer, then again and now again not.
What else can I check to find the error?
Greetings from Stefan Harbich
MOD EDIT: Token scrambled
