Blurring track number and track name on track listing
Just want to say been using Plex for years and love it, keep up the great work.
I have a small problem and I may have created it by changing a setting or font or something I don’t know. All I know is that on music tracks the track number is blurred with the track name. This is not a program breaking bug but I was wondering how I can separate them like I used to see them so it just looks more pleasing to the eye.
I have included a jpg of how the screen looks
tracklisting
Thanks for any help you can provide.
Is this in Plex Web? If so, which browser?
This is in a browser. I have always used Firefox with Plex
It is Firefox just checked it in Chrome and it shows up correctly. Damn Firefox. I always keep Firefox up to date and hopefully it it fixes itself.
Any changes in the browser? New extensions added, maybe? I use Firefox as well, and I’m not seeing this, so something’s interfering.
Can you restart Firefox with add-ons temporarily disabled? If the problem goes away in that case, you can start figuring out which extension is causing it.
Thanks for the advice I will give it a try
You were right restarted Firefox in trouble shooting mode and it fixed it. Now will have to figure what add-on is causing the problem.
Just went back to Firefox regular mode and everything looks alright. Guess going into trouble shooting mode and back to normal fixed it. Thanks for all your help. Have a great day.
Cool. Might have been something cached.
This is actually a known issue. Unfortunately there has been no cause identified yet.
It can always be fixed with a reload of the app in your browser (F5).
Yeah, that’s what I meant to say… :innocent:
This seems to not been isolated to Firefox. I just had this happen momentarily on Edge browser until I F5’d it and it was normal again. Definitely a bug on more than one browser.
