Server Version#: 1.32.8.7639
Player Version#:10.5.0.4996
<Good morning
On nVidia Sheild this version of bootloop application has the opening (opening/closing) about ten times.
Reset + KO cache
Force to revert to version 10.4 to return to normal behavior.
Greeting>
Which model Shield do you have?
Would you mind trying the current beta https://play.google.com/apps/testing/com.plexapp.android
Good morning
Model SHIELD TV P3430 version 11
I have 2 pieces of equipment, it worked on both.
I’m testing the Beta and you’ll get back to me but I wouldn’t leave it in production.
can you tell me the beta version to test pleaze?
Greeting
You can use the link above to join beta program and update from the store
Or manually get the latest beta 10.6 apk here to sideload. Release Announcements - Android TV beta - #660 by PlexAndroidReleaser
