Broken on Xbox one S and Fire TV after update - unusable
Ever since the most recent update plex has basically been unusable for me. On the Xbox One S it tells me on every single video bandwidth not available. Xbox One S is displaying at 4k resolution. If I switch to my fire tv (4k model) the display is set for 1920x1080 as that is what plex runs at. All videos play BUT the audio cuts out every few seconds. My network is unchanged it is 300/30 and when I switch to kodi running on my fire tv the same video plays with zero issue. If I play plex on my regular xbox in a different room, it skips as well.
I tried downgrading my version using the exe’s in the update folder, but every older version now gives me failed codecs. I have reinstalled, rebooted, reset network, several times and nothing works. If I try remote play from web app, it buffers every few seconds and stops. Plex is basically dead for me now, and I don’t know what to do. I attached my logs.
So I used someones speedtest plugin and I get 207/30. I feel like I have more than enough. Can anyone help?
I’m having the same issue after this most recent update. I’ve gone into the registry of my windows machine and deleted the program, reinstalled, and done everything I can think of and its still no good. What is the issue??? Everything was working just fine before this
