WebOs 3 on my LG TV it was was working great. However when I unplugged the TV and tried to use it again when the sign in screen came up it tried to generate a code but then I got the BUDAPEST error. I uninstalled the app and reinstalled and the same error. I done a factory reset of the TV and installed the app again and it was working. Then I unplugged the TV again and the BUDAPEST error came up again. Having tried different methods to resolve the issue (remove the device from the media server) (setting my TVs IP address in the exclude sign in on the settings page in PMS) the error is still there. It seems to only way to get the app to work is to reset the TV every time, which I shouldn’t have to do. How do I go about fixing this issue?
Same issue Plz fix it.
Exact same problem here - only way to get around it is to do a full factory reset of the TV and take 20 mins to setup again from scratch. Then it will work once. Next time you switch it on, can’t generate a code, and get the ‘Diagnostic - BUDAPEST’ error. Would appreciate any guidance.
Sorry guys. We’ve identified the issue and working on a fix. No ETA yet.
The BUDAPEST code is now back on my Vizio TV since this morning. Plex was running fiine yesterday, no configuration changes since.
Same here
The issue persists. Any resolution?
