So I have this issue with a few shows/movies. All are 4K HDR MKV files.
They all Direct Play. My Synology is old and crappy so couldn’t transcode
This issue only just started even with some movies that a few months ago played fine without any buffering issues.
I have included server logs captured just after the issue happened. A quick search for “buffering” brings up some stuff but tbh I don’t know enough about it all to properly understand it.
I also included an xml output for the current problem episode which is WandaVision as you can see
Yes I am using subtitles, srt built into the mkv file however testing with subtitles disabled also buffers so I don’t think the subtitles are to blame?
What other information can I provide to help get to the bottom of this?
Just so you know I am using the native LG webOS Plex app from the LG Content Store. The TV is using a 5Ghz wifi connection that speed tests to ~300Mbps and the NAS is obviously connected via gigabit ethernet and speed tests internally with iperf gets me over 930Mbps so network speeds shouldn’t be the issue! I have also tried with the TV connected via ethernet but as the LAN port on the TV is limited to 100Mbit it is “better” to use wifi as sad as that is in 2021. Ah well!
Hopefully someone can help me get to the bottom of this. Thanks in advance! Also included is a screenshot of the dashboard that tells me it is using direct play but I don’t know how honest that information really is, perhaps it is having to do some kind of stream mangling or something??
Server Version#: 1.18.5.2309
Player Version#: LG OLED55C8PLA 5.8.1, Plex for LG, webOS 4.3.0
Plex Media Server Logs_2021-02-06_22-40-02.zip (5.1 MB)
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="3" librarySectionTitle="TV" librarySectionUUID="bff24d4b-3c1f-48a1-a1d5-97118611a961" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1579823912">
<Video ratingKey="1558" key="/library/metadata/1558" parentRatingKey="1444" grandparentRatingKey="1443" guid="com.plexapp.agents.thetvdb://362392/1/5?lang=en" parentGuid="com.plexapp.agents.thetvdb://362392/1?lang=en" grandparentGuid="com.plexapp.agents.thetvdb://362392?lang=en" type="episode" title="TBA" grandparentKey="/library/metadata/1443" parentKey="/library/metadata/1444" librarySectionTitle="TV" librarySectionID="3" librarySectionKey="/library/sections/3" grandparentTitle="WandaVision" parentTitle="Season 1" contentRating="TV-PG" summary="" index="5" parentIndex="1" viewOffset="525067" lastViewedAt="1612647727" year="2021" thumb="/library/metadata/1558/thumb/1612525474" art="/library/metadata/1443/art/1612525474" parentThumb="/library/metadata/1444/thumb/1612525474" grandparentThumb="/library/metadata/1443/thumb/1612525474" grandparentArt="/library/metadata/1443/art/1612525474" duration="2292864" originallyAvailableAt="2021-02-05" addedAt="1612525459" updatedAt="1612525474">
<Media id="2997" duration="2292864" bitrate="22146" width="3840" height="2160" aspectRatio="1.78" audioChannels="6" audioCodec="eac3" videoCodec="hevc" videoResolution="4k" container="mkv" videoFrameRate="24p" videoProfile="main 10">
<Part accessible="1" exists="1" id="2997" key="/library/parts/2997/1612525386/file.mkv" duration="2292864" file="/volume1/Media/TV/WandaVision/WandaVision.S01E05.HDR.2160p.WEB.h265-KOGi.mkv" size="6348124090" container="mkv" deepAnalysisVersion="4" requiredBandwidths="25288,24759,23612,23371,23371,23371,23371,23371" videoProfile="main 10">
<Stream id="7958" streamType="1" default="1" codec="hevc" index="0" bitrate="21377" language="English" languageCode="eng" bitDepth="10" chromaSubsampling="4:2:0" codedHeight="2160" codedWidth="3840" colorPrimaries="bt2020" colorRange="tv" colorSpace="bt2020nc" colorTrc="smpte2084" frameRate="23.976" height="2160" level="150" profile="main 10" refFrames="1" requiredBandwidths="24520,23990,22842,22604,22604,22604,22604,22604" width="3840" displayTitle="4K (HEVC Main 10 HDR)"/>
<Stream id="7959" streamType="2" selected="1" default="1" codec="eac3" index="1" channels="6" bitrate="768" language="English" languageCode="eng" audioChannelLayout="5.1(side)" requiredBandwidths="767,767,767,767,767,767,767,767" samplingRate="48000" displayTitle="English (EAC3 5.1)"/>
<Stream id="7960" streamType="3" selected="1" codec="srt" index="2" bitrate="0" language="English" languageCode="eng" requiredBandwidths="1,1,1,1,1,1,1,1" title="English (SDH)" displayTitle="English (SRT)"/>
<Stream id="7961" streamType="3" codec="srt" index="3" bitrate="0" language="Dansk" languageCode="dan" requiredBandwidths="1,1,1,1,1,1,1,1" title="Dansk" displayTitle="Dansk (SRT)"/>
<Stream id="7962" streamType="3" codec="srt" index="4" bitrate="0" language="Deutsch" languageCode="ger" requiredBandwidths="1,1,1,1,1,1,1,1" title="Deutsch" displayTitle="Deutsch (SRT)"/>
<Stream id="7963" streamType="3" codec="srt" index="5" bitrate="0" language="Español" languageCode="spa" requiredBandwidths="1,1,1,1,1,1,1,1" title="Español (Latinoamericano)" displayTitle="Español (SRT)"/>
<Stream id="7964" streamType="3" codec="srt" index="6" bitrate="0" language="Español" languageCode="spa" requiredBandwidths="1,1,1,1,1,1,1,1" title="Español" displayTitle="Español (SRT)"/>
<Stream id="7965" streamType="3" codec="srt" index="7" bitrate="0" language="Suomi" languageCode="fin" requiredBandwidths="1,1,1,1,1,1,1,1" title="Suomi" displayTitle="Suomi (SRT)"/>
<Stream id="7966" streamType="3" codec="srt" index="8" bitrate="0" language="Français" languageCode="fre" requiredBandwidths="1,1,1,1,1,1,1,1" title="Français (Canadien)" displayTitle="Français (SRT)"/>
<Stream id="7967" streamType="3" codec="srt" index="9" bitrate="0" language="Français" languageCode="fre" requiredBandwidths="1,1,1,1,1,1,1,1" title="Français" displayTitle="Français (SRT)"/>
<Stream id="7968" streamType="3" codec="srt" index="10" bitrate="0" language="Bahasa Indonesia" languageCode="ind" requiredBandwidths="1,1,1,1,1,1,1,1" title="Indonesian" displayTitle="Bahasa Indonesia (SRT)"/>
<Stream id="7969" streamType="3" codec="srt" index="11" bitrate="0" language="Italiano" languageCode="ita" requiredBandwidths="1,1,1,1,1,1,1,1" title="Italiano" displayTitle="Italiano (SRT)"/>
<Stream id="7970" streamType="3" codec="srt" index="12" bitrate="0" language="Nederlands" languageCode="dut" requiredBandwidths="1,1,1,1,1,1,1,1" title="Nederlands" displayTitle="Nederlands (SRT)"/>
<Stream id="7971" streamType="3" codec="srt" index="13" bitrate="0" language="Norsk" languageCode="nor" requiredBandwidths="1,1,1,1,1,1,1,1" title="Norsk" displayTitle="Norsk (SRT)"/>
<Stream id="7972" streamType="3" codec="srt" index="14" bitrate="0" language="Português" languageCode="por" requiredBandwidths="1,1,1,1,1,1,1,1" title="Português (Brasil)" displayTitle="Português (SRT)"/>
<Stream id="7973" streamType="3" codec="srt" index="15" bitrate="0" language="Português" languageCode="por" requiredBandwidths="1,1,1,1,1,1,1,1" title="Português" displayTitle="Português (SRT)"/>
<Stream id="7974" streamType="3" codec="srt" index="16" bitrate="0" language="Svenska" languageCode="swe" requiredBandwidths="1,1,1,1,1,1,1,1" title="Svenska" displayTitle="Svenska (SRT)"/>
</Part>
</Media>
<Extras size="0"> </Extras>
</Video>
</MediaContainer>```
