I would like to ask the help of other forum members to collect data to help diagnose this issue, in order to find a solution. Only ATV3 users please (test film uses 20MBps bitrate and is not suitable for ATV2).
Tests must be performed using the same test video (video, setup and report instructions here). For each test I need some info. As an example, here is a template filled with my own data:
Test date - Aug 28, 2015
Test result - buffering starts at ~01:07:00 after start
ATV HW - ATV3 Rev. A
ATV SW - 7.2
HDMI connection - 720p 60Hz
PlexConnect HW - Synology DS411slim
PlexConnect SW - 0.5-dev-020615
Python version - 2.7.9
Fanart enabled - Yes
PMS HW - Synology DS411slim
PMS SW - 0.9.12.11
ATV and PMS connected to same router / switch - Yes
Cat5e cabling (or better) - Yes
Special cabling (if yes pls describe) - ATV connected with 2x tplink av500 (powerline)
PMS HW - Mac Mini 2011, OS X 10.9.5. Core i5, SSD for OS, another SSD for data, 16GB of RAM
PMS SW - 0.9.12.8
ATV and PMS connected to same router / switch - No. aTV connected to airport express in 1Gb/s Ethernet, airport connected to one Internet access Box with 1Gb/s integrated switch, MacMini and Box connected through a 1 GB/s dedicated switch. All Ethernet connexions.
Cat5e cabling (or better) - accessible : yes / not accessible possible (integrated in walls)
Special cabling (if yes pls describe) - yes : movies are on a Dlink DNS323 NAS connected on the dedicated 1Gb/s switch.
All connexions are 1GB/s
Tested with my own content with multiple containers and codecs 720p/1080p dd/dts/2.0.
Test date - Sep, 16 2015
Test result - buffering starts randomly requiring aTV reboot
ATV SW - 7.2
HDMI connection - 1080p 60Hz
PlexConnect HW - In my signature
Python version - 2.7.10
PMS HW - In my signature
PMS SW - 0.9.12.11
Special cabling (if yes pls describe) - ATV connected with DirecTV broadband deca’s (coax to ethernet converters) *Also tested with aTV on wifi & using a jailbroken iOS device as a PlexConnect host. All methods had the same result.
Thanks to all that participated in this thread. After thinking a lot I think that I have found the solution for this problem.
I have modified every OPEN statement in application.js and utils.js so that its 3rd parameter is always false (currently some of them are true, false forces synchronous communications between AppleTV and PMS), and then restarted PlexConnect and AppleTV.
Now I hope that others confirm that this solution works, and eventually PlexConnect developers change the base code.
Three shows in and its working strong! I hope this is it. Will edit post if needed, but so far so good! Even on the worst show I had issues with, Fringe.
