[Bug] 6.13.0 hue lights plugin
Not sure if you guys will be able to reproduce the bug.
I use the above plugin with my hue lights to turn the lights off when starting a tv show then turn back on when show has finished.
Since 6.13.0 when the file finishes the lights turn back on then quickly turn off again.
Going back to previous versions of plex for Android the correct steps are in order.
Turn lights back on when file is finished and keep lights on.
If anyone else users the plugin and could test that would be great!
