Hello,
i want to make a plugin that works with the pihlips Hue system. So that if you start a movie the lights change the color (or dim). So is it posible tomake a plugin that works with a playing film? Like if you set pause the movie, the light go be lighter then when you play a moivie? like the XBMC app?
