[BUG] Beta 7.22.0.12467 - Android TV - TV Season/Episode Browsing Bug
When browsing TV episodes and seasons, it requires two presses of the rightward button to move to the next card. This bug does not happen when browsing any other categories (that I can tell), and does not happen in the leftward, up, or down directions either. Only when browsing either seasons or episodes of TV shows, and only when moving rightward in the menus.
I haven’t tested to the same degree as the original poster but I can confirm that I have seen this bug too. When you attempt to move between episodes the first press on the remote causes the focus to be lost before a second press successfully moves it to the next episode.
I have the same issue. I’ve noticed it happens when pressing the right button, but when pressing the left button it works as expected.
Hi. I noticed the same thing today as well on my Nvidia shield.
Only checked the movies library, so may be effecting other libraries
I should note that this problem appears to be fixed for me in beta 7.23.0.12806, though I did not see it mentioned in the patch notes.
