[bug]Can not play in Plex
The video uses Plex to play, which can not work!
test vedio in the below comment and the record in attachment
SOME RECORD BY MY PC
Plex 2022.12.29 - 22.08.39.01.zip (7.9 MB)
And here is the sample video, which you can test.
Thank you!
The problem is solved. If someone encounters the same problem, try the following methods:
#####For IOS you can:
turn on old video player
#####For win-PC you can:
Turn off Hardware decoding
