[BUG] Errors in English/source strings in Transifex
7 stings in the English/source files for the React Native Client have errors. The strings appear to be misconfigured in Transifex as the plural forms are not able to be edited.
I have reported the strings in Transifex. They can be seen under “Issues” in the React Native Client project.
I’m posting here as the Transifex problem reports appear to go unseen.
This Transifex help article shows how plurals are supposed to be handled:
https://help.transifex.com/en/articles/6231958-working-with-plurals-and-genders#h_51e09ec18a
Somehow I only count 4 strings which are untranslatable now.
All others are perfectly fine.
Could you please mention the string numbers of those which you think might be affected?
grafik
Hi, thanks for your reply.
If I go to React Native Client —> Danish (da) —> filter by “issue:open” then they all show up for me.
The string numbers are:
627
689
850
900
913
944
955
Thank you! You are right, all these strings have an issue.
This particular issue is already known, but I will nudge someone again.
Hi again! I see a new file was added for translation in the React Native Client project. The new file “apps..translations/en.json (main)” has two of the same problems as the old file.
The affected strings are:
74
1110
It appears that the rest of the problematic strings have been removed, though.
