Bug found in recording - same episode multiple times doesn't work
Plex version: 1.13.8.5395
I recorded part of a shark episode called ‘Shark attack file’.
As I didn’t get the start of it, and it was repeated the day after, I then marked that as well.
But it failed, and reported a ‘transcoder error’, I guess the naming of the file is very strict, and it can’t have two identically named files, as it will place them in the same folder.
I consider this a bug, and it could be solved if the file was named with the date/time/channel of the recording, which it is also lacking in the metainfo for the recording.
This seems to have been solved in the later versions, though it STILL doesn’t note WHEN it was recorded.
