Bug: Greek words can only be searched if case sensitive
The issue is a case sensitive issue. So I’ve tried again searching. What I have noticed is that it is not showing any results if Greek characters are not 100% as the metadata shows it. Whereas with English titles it’s not case sensitive. I’ve put an example where 12 Years Slave , is searched sLaVe and it shows results, on the other hand if in Greek Σ(capital for s), is not capital so ‘‘σ’’ it won’t show anything. Thus, in order for Greek characters to show I need to capitalise them or lower case them depending on how they are on metadata. So this is the issue.
An update will get released in the coming weeks, which may bring some improvements.
Have you had a chance to test search in the recently released server version 1.22.1, yet?
It is supposed to bring improvements search with non-latin alphabets.
Can I kiss you? Can I hug you? because this fixed the issue! Thank you so much!
