Old search had and new search has the same bug: it is case sensitive if I use cyrillic characters.
How to reproduce the bug?)
Try to search something with cyrillic for example “Карточный домик” will find house of cards, however, typing “карточный домик” finds nothing.
Please fix this as it should be an easy fix.
“We’ve incorporated an advanced spell-checker into your searches” , Spell checker but case sensitivity… rly???
Ubuntu 14.04.4
plex 0.9.16.4
PMS is so busy dealing with the networking failure and resetting itself, nothing can complete in time. When you type in the value correctly, it finds it before the next network retry. You are literally on the edge of nothing working, from what I can see
I do have a bug report ready to submit but we first need to clear up the other errors and give engineering a clearly valid problem. If I submit it now, they will reject it
Nov 19, 2017 08:44:14.571 [0x2b45e4c01700] INFO - Plex Media Server v1.9.7.4460-a39b25852 - ubuntu docker x86_64 - build: linux-ubuntu-x86_64 ubuntu - GMT -08:00
Nov 19, 2017 08:44:14.571 [0x2b45e4c01700] INFO - Linux version: 4.9.30-unRAID (#1 SMP PREEMPT Fri May 26 13:56:36 PDT 2017), language: en-US
Nov 19, 2017 08:44:14.571 [0x2b45e4c01700] INFO - Processor AMD Athlon(tm) X4 860K Quad Core Processor
Nov 19, 2017 08:44:14.571 [0x2b45e4c01700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Nov 19, 2017 08:44:15.041 [0x2b45e6602700] INFO - Successfully retrieved OCSP response
Nov 19, 2017 08:44:20.041 [0x2b45e8a46700] INFO - Refreshing paths watched by LibraryUpdateManager
Nov 19, 2017 08:44:20.414 [0x2b45eca00700] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Nov 19, 2017 08:44:24.375 [0x2b45ee208700] INFO - AutoUpdate: no updates available
Nov 19, 2017 08:44:29.327 [0x2b45eee16700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (b6c84e89-d180-427b-bce5-1dd4a331d37d, expected 6a22df46-4e84-4f1d-a46b-40f82e7f831b)
Nov 19, 2017 08:44:30.073 [0x2b45eee16700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (3ce7e636-2821-46bf-be7e-b91962cf97fb, expected f30cbaea-486e-4a79-94d6-bf779e9836f5)
Nov 19, 2017 08:44:30.370 [0x2b45eee16700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (6a22df46-4e84-4f1d-a46b-40f82e7f831b, expected f30cbaea-486e-4a79-94d6-bf779e9836f5)
Nov 19, 2017 08:45:14.835 [0x2b45ee409700] INFO - AutoUpdate: no updates available
